![]() | Home > Technical > central locking - grrrhh ! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Don't know for sure yet. Central locking to rear o/s door has stopped working again and assume it's the wiring again....at same time I found trailer brake light isn't working so assumed it was socket wiring again but looks like it's nothing more than a blown bulb but won't know till I get caravan back again.
Rumbling etc is getting worse so suspect front diff is shot ![]() |
Oscar Romeo Member Since: 16 Apr 2014 Location: South Yorks, the pinnacle of all human achievement Posts: 121 ![]() ![]() ![]() |
Does it lock after its been manually unlocked?
If it were mine, i would have the door card off, check for bad connections to the motor. If this didn't produce anything i'd remove the loom out of the door back to the b pillar. Then examine for damage and test continuity of each wire. If this still didn't yield any results i would be inclined to see if voltage is present at the motor by using the test light on my voltage probe. The fact it doesn't work at all makes it so much easier to find. Let us know how you go on? |
As you've suggested it should be simple to find / resolve....find the time might not be so easy.
on a 2011 defender you've had 2 of the aux socket sockets in the rear speaker panel corrode and break off ?? was the copper wire green and corroded ? |
Yes like a load of flux was left on to make it corrode.
Never got an explanation from LR for that? |
thats terrible on a 2011 defender , I would get some battery terminal spray and give the socket a spray to stop any corrosion again
or cut wire right back to find bright copper then use that part as once wire has corroded ( gone green ) you're never get a good cornection or solder joint , normally wire will be black back up the wire from the corroded part on the end |
Sorry mate i am even more confused, what is your issue and how can we help?
I think (hope) the issue is no more than simply the fix that was done 6 months ago by LR needs fixing again (hopefully its nothing more than a break in the cable from b pillar to door but I need to find the time to have a look.
will let you know once I have had the door card off etc. |
So door harness replaced and now working a treat again.
While I was at it put half a sheet of dynamat in the door ![]() |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
Reading this makes me glad I just specified the 'olde worlde' wind up/down windows. Something else not to go wrong.
me too windy up ones........in the back at least where the children sit !
![]() front ones have been faultless...... ![]() so 3 more doors to do with the dynamat. will given em all a squirt of acf 50 and lubricants etc while I'm at it. ![]() |
Drivers door has been struggling to on/close to to central locking and has now stopped working.
What's th answer - please don't say oil in the key hole as i've done a shed load of that's and to no avail. Any other ideas? I'm guessing one of the pivots inside the door and is corroded / seized? |
update.
the solenoid has been disconnected from the locking mechanism but still goes woa woa woa and doesn't move. wiring or solenoid? I'm trying to get a new loom (just can't be ars'd with trying to repair the wiring - if that's what it is). do you reckon it's more likely a knackered solenoid than wiring? how much to replace the solenoid? many thanks. |
I replaced one second row solenoid that sounded to be going slow for ages, then it stopped all together but the new one works perfectly. Only trouble is, I can now hear how slow the opposite side second row one sounds so it looks like I'll be replacing that one too quite soon
![]() I think the new solenoid was about £60 ish Ray My build thread http://www.defender2.net/forum/topic17615.html |
