Home > Technical > central locking - grrrhh ! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
thanks Ray.
don't you just love em. this I'll be the second replacement to that door in less than 6 years (know any other car manufacturers that regularly have to replace central locking issues - I don't?) I'm guessing it would be easy to test the solenoid....just need to know which pins to apply 12V. can anyone enlighten me? many thanks, |
11th Jan 2016 4:47pm |
solenoid has arrived so I'll be fitting tonight and putting door card back on .....just hope it was the solenoid and not the wiring
anyhow I noticed last night the hand brake light has also stopped working - just so happens the CHT sensor is disconnected and the door solenoid aint' working ....must be coincidence as they can't be connected in any way - can they? unfortunately this is my 3rd one but on the + side they're only about £20 each so I guess that's no worse that perhaps having a German one last about 6 years but cost about £80 ? It's all relative....I think some of our complaints should be put into perspective - bumpers corroding after 2 or 3 years.....but they only cost about £40 to replace so I guess that's probably acceptable? |
14th Jan 2016 9:11am |
Trial fitted and works
Will fit later. |
14th Jan 2016 6:18pm |
Can I ask where you got a solonoid for £20? I'm sure mine was about £50/60 Ray
14th Jan 2016 6:25pm |
From the local LR dealer.
Let me find the invoice and i'll confirm. |
14th Jan 2016 8:29pm |
It's like music to my ears now...a quick sharp clunk rather than the moaning groaning similar to that of its owner
A bit cold out there tonight fitting and cleaning and adjusting things. Sorry go price wrong - I remember being chuffed at 20 something....£29.16....+vat. So £34.99 all in. Still no bad huh? |
14th Jan 2016 10:02pm |
which door was it for and do you have a part number?
Edit: just read it was the drivers door but would still like the part no if you have one Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Jan 2016 10:46pm |
Morning Ray.
I presume from the paperwork the part no is LFUD500020? Description of n/stk switch - alarm? They also quoted £62 +vat . 4no glow plugs which I thought was very reasonable. Anyhow last night was very successful : working door lock, hand brake adjusted very slightly and hand brake light wiring repaired....and a runny nose. |
15th Jan 2016 7:10am |
thank you I'll try and find the box for the one I bought and see if I was ripped off. Ray
15th Jan 2016 9:45am |
it's not been so cold recently but I'm still loving the quick click open / shut. sounds sooo much better. |
25th Jan 2016 7:31am |
