Home > Maintenance & Modifications > Mobile Storage Solutions Superline Drawer Modification
These units are designed with a space saver door to the right of the unit, which creates a full-length storage area:
However, it is not possible to open the door enough to use the space when you have a vehicle with a tailgate because of the right hand tailgate bracket.
So off with the door:
and on with a template to see what needs cutting out to make the door useable:
Cut out the rectangle and re-fit using stainless bolts:
Just need to find a recessed blanking plug/grommet to finish it off, sorting though my collection, I had nothing that did the job perfectly:
Plan to use the space for a breaker bar with extension and it also looks idea for tent poles when making trips.
Post #337880 13th Jun 2014 9:33am
smb
Good thinking Thumbs Up . You can also look at cutting the door and inch in from the hinge and fitting an additional hinge. A bit more work, but very good at solving similar issues. Haven't done it myself(don't need to), but saw what someone else had done.
Post #337888 13th Jun 2014 10:04am
Hadn't thought of that, it would be neater and more original looking - but would that narrow down the opening and make getting things in and out that little bit harder?
Post #337889 13th Jun 2014 10:10am
smb
It would, but only above and below the tailgate bracket as the bracket already restricts 'clear' opening. However, thinking about it you could in fact cut out a door like you have done and secure the cut out on a hinge and spring load it so it always looks as one until it touches the bracket. If you get what I mean, but could be more hassle than it is worth Idea
Post #337895 13th Jun 2014 10:43am
landy andy
Just removed mine.
Post #337915 13th Jun 2014 12:50pm
I do - off to look for the cutout bit in the bin... Whistle
Post #337917 13th Jun 2014 12:59pm
Landy Andy - that's only half a job - where's your imagination & a little garage engineering!
Is that a full length one? If so does the left hand front edge catch on the tailgate support every time you open it fully?
Post #337918 13th Jun 2014 1:02pm
