Home > Maintenance & Modifications > SNORKEL ! Mantec or Land Rover ?
Page 6 of 7 <1234567>
mse
Ill know at the outrun of this tank.
But im sure the safari is improving fuel consumption by about 3-6mpg.
It is certainly making the car more drivable. Mike
Post #33757 5th Jun 2010 9:30am
K9F
Mse,
Mine too! But my induction growl I used to get has now gone! Big Cry Never mind it looks cool too! Bling bling!!! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33760 5th Jun 2010 10:17am
mse
The most important factor surely Shocked Rolling with laughter Mike
Post #33762 5th Jun 2010 12:24pm
K9F
Naturally! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33767 5th Jun 2010 3:09pm
MK
I used it today on a 200 km trip. I felt the engine going smoother.....very subjective though. I�ll check mpg`s on monday after the same trip. Puma 110" SW
Post #33791 6th Jun 2010 1:38am
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Was contemplating an RAI for my puma but I want this one http://c0007716.cdn2.cloudfiles.rackspacec...hicles.png
From what I understand you cant get it anymore. It is just the rectangle one. With the mantec one for a td5 not work?
Post #59423 16th Feb 2011 7:37pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I agree with all that's been said. I used the masking tape, new drills etc: I also used a large amount of Silicon Grease - NOT the sealant - but very high melting point grease on the rubber/foam seal and under the A pillar bracket as well as around the rivnuts on the wing. As they say, measure 2 x and Drill 1x.
Post #59461 16th Feb 2011 10:17pm
m_plewes
It is still available from mantec, as is the older metal version and both fit the puma. My friend has had the one you want on both his puma 110's.
http://www.mantec.co.uk/productdetail.cfm?...3D6B187B27
German mantec stockists listed here: http://www.mantec.co.uk/stockists.cfm
Post #59732 17th Feb 2011 10:58pm
Glynparry25
I fitted my new MANTEC metal (for roll cage) snorkel with ARB pre-filter at the top.
I must admit I was supprised with the MANTEC kit- it has EVERYTHING including a tube of clear sealent and instructions of how to completely seal the whole system. After the PPC abonimation I am super happy with what I am left with Mr. Green
Now all I need to do is find some water 5 foot deep!!
Glyn Dog Sheep
Post #59735 17th Feb 2011 11:05pm
BigMike
Gln, any chance of you scanning the sealing bit? I've looked at mine but i cant see if there are any gaps
Post #59744 17th Feb 2011 11:37pm
Glynparry25
Mike,
Sealing bits were:
-Wing to first plastic box.
-Plastic box to tube.
-Tube to Air box.
-Water drain thing in the air box.
The good thing about the metal one is that it uses bolts and captive nuts so you can really tighten the inner plastic box to the outer bit with the wing sandwiched in the middle Smile
Glyn Dog Sheep
Post #59747 17th Feb 2011 11:45pm
BigMike
Ah ok, cheers. I thought it was some kind of mystical black art Laughing
still, was in water up to the wing mirrors this week (the front anyway). Will post a pic of the filthy truck if I get a minute tomorrow. As previously, the only water was a small amount in the footwells and probably the battery box which I must check in the morning. Am seriously considering some of Peters Double seals.
Post #59768 18th Feb 2011 2:02am
defender75
Cool thanks. I wrote mantec and asked and got the answer you guys gave.
Post #59771 18th Feb 2011 5:06am
Jaeger
Norway 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Anyone tried out this one?
http://nakatanenga-tours.de/shop/article_S...%2520AL%26
Like the style of it (looks like it's there for a reason), and it's practical, a oil bath that sorts out dust and particles. Anyone?
Post #61291 27th Feb 2011 3:00pm
Glynparry25
Knowing Peter the kit will be awesome and of the highest quality.... the only problem is the price. A mantec will cost someone in the UK less than �200... where Peter's is over �400
I bought a centrifugal pre-filter for mine... Was �180 for the snorkel and then another �50 for the pre-filter, so only about �230 all in which included EVERYTHING to fit it to the vehicle and seal the system up.
Peter's would have been my next choice if the Mantec didn't fit.
Glyn Dog Sheep
P.S. Jaeger, I will reply to your PM later today (Have rugby to watch) Smile
Post #61292 27th Feb 2011 3:29pm
