![]() | Home > Technical > Td gearbox question |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Could also be propshaft UJ's or splines, and the drive hubs. these wear a bit and give a really bad "clunk",
Or a combo of all of the above. |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I've just had a look underneath, the UJ's look ok and no slack, the front prop moves more and clunks a bit when turned by hand, the rear prop moves but a lot less with no clunk. Any idea's?
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Play in the diffs or hub driving member, or both.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Have you checked the rear a-frame ball joint. This made an aweful clunk on gear changes in ours but had no real visible play until I got a HUGE pry bar on it - the play was obvious then.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Steve, yes the A frame joint is new about 3 months ago, that's fine but thanks for pointing it out. It's more of a slight metallic clunk when the clutch is released, if done slowly then it's not a problem, and when driving there is no sloppiness, just when the clutch is released, especially when pulling away.
There is a round cover on the back of the transfer box behind that is a cogwheel that tranfers the drive from the gearboz to the transfer box. These wear fast by lack off lubrication specially if not used that often. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Thanks Roel, is that something that can be replaced easily? Will I be able to tell if there is wear by taking the cover off and looking inside? I've swapped a transfer box off before but never had the cover off.
I've just been underneath again and it looks like the transfer box might have wear issues, there's quite a bit of movement when grabbing and turning the props by hand, the clunk seems to be coming from inside the transfer box, more so when turning the front prop. |
