Home > Technical > Td gearbox question
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Td gearbox question
I've got an old pickup that I use regularly for fishing trips etc, it's in great condition and only done 68k miles which has to be low for a 1989 vehicle.
The only problem with it is the gear change is sloppy, I have to be steady on the clutch when changing and 'ease' the clutch out gently to avoid a 'clunk'.
I've not had the box or transfer box off yet but I suspect the mainshaft is worn. If that's the case - is it easier to buy a recon gearbox and be done with it?
Could it be something else? I know it's difficult without having a good look but wondered if anyone with an LT77 gearbox had had a similar problem and sorted it?
Post #335439 3rd Jun 2014 1:13pm
Could also be propshaft UJ's or splines, and the drive hubs. these wear a bit and give a really bad "clunk",
Or a combo of all of the above.
Post #335445 3rd Jun 2014 2:04pm
Lambley
I've just had a look underneath, the UJ's look ok and no slack, the front prop moves more and clunks a bit when turned by hand, the rear prop moves but a lot less with no clunk. Any idea's?
Post #335453 3rd Jun 2014 2:55pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Play in the diffs or hub driving member, or both.
Post #335459 3rd Jun 2014 3:19pm
rallysteve
Have you checked the rear a-frame ball joint. This made an aweful clunk on gear changes in ours but had no real visible play until I got a HUGE pry bar on it - the play was obvious then.
Post #335462 3rd Jun 2014 3:53pm
Lambley
Thanks Steve, yes the A frame joint is new about 3 months ago, that's fine but thanks for pointing it out. It's more of a slight metallic clunk when the clutch is released, if done slowly then it's not a problem, and when driving there is no sloppiness, just when the clutch is released, especially when pulling away.
Post #335465 3rd Jun 2014 4:02pm
roel
There is a round cover on the back of the transfer box behind that is a cogwheel that tranfers the drive from the gearboz to the transfer box. These wear fast by lack off lubrication specially if not used that often. Roel
2003 90 Td5 (2009-now)
Post #335471 3rd Jun 2014 4:20pm
Lambley
Thanks Roel, is that something that can be replaced easily? Will I be able to tell if there is wear by taking the cover off and looking inside? I've swapped a transfer box off before but never had the cover off.
I've just been underneath again and it looks like the transfer box might have wear issues, there's quite a bit of movement when grabbing and turning the props by hand, the clunk seems to be coming from inside the transfer box, more so when turning the front prop.
Post #335473 3rd Jun 2014 4:28pm
