Home > Puma (Tdci) > ok but what happened? (impossible to start) |
chris bb Member Since: 14 Feb 2014 Location: South Hampshire Posts: 28 |
Thank God it's not just mine. It only happens occasionally but when it does it's very annoying to say the least. I have had to do the "lock/unlock" routine up to 10 times to get the thing to agree to start. I reported this to the main dealer who looked at me as if I'd just come from the planet Zog! They "tested" the car and checked the diagnostics but found no faults. It also used to happen to a Subaru Legacy, that main dealer said that they were aware of it, typically on expensive cars, but had no idea how to cure it. Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
26th Mar 2014 10:33am |
Zouritte Member Since: 29 Jan 2014 Location: Ain Posts: 69 |
Hi
Lately I had this problem again, and more and more often, until being blocked for two times, and having to call the Truck to pick me up.... Once in the middle of the forest after a picnic.... So the Def went to the dealer and the problem was the same as "blackwolf" a loose main relay. So the tech re did the connection and the def is -so far- good!!! Thanks to all of you for your help!! Tim |
31st May 2014 6:36pm |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
This just happened to me, symptoms were reluctant starting, cranking but not firing, stop/start starter motor engagement and finally today the burning smell that gave it away - I had thought it was an iffy immobiliser because it was very intermittent.
I found that the main feed from the battery to the fuse box terminal was loose causing high resistance, melted plastic and potentially fire. One side of the 100A fuse link was discoloured too. Just updating this thread incase it helps someone else out. Luckily I just have a bit of melted plastic around the terminal and the whiff of smoke. Dread to think of the damage that could have occurred if it had gone on. |
9th Aug 2014 2:58pm |
Hey,
About my problem, i had the main relay for the feed to the ECU who had loose connexion. the dealer remade the connexions and it's all fine now. Could have done it myself but didn't know where to look. This relay is located under the passenger seat (LHD). Tim |
9th Aug 2014 3:44pm |
