Home > Maintenance & Modifications > Stainless steel EGR blanking kits |
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 |
Sorry i,m abit slow at the min trying to drive a tractor in a straight line in a massive field and reply with my iphone at the same time. The kits are now 35 pounds plus p&p but thats for the few i have left. 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
27th May 2010 8:49am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2047 |
Robofarmer, I have sent you the money for the EGR blanking kit via my brothers pay-pal account.
Thanks Daz110 |
27th May 2010 2:49pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
whats the smallest hole then becos im guna fit the 12mm one when i get 5 mins spare any one gone smaller yet ? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
31st May 2010 11:17am |
14 mm fitted today...slightly behind you on the small orifice stakes. Always leave it a couple o'weeks before venturing smaller.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st May 2010 5:42pm |
I,v been using a 14mm plate for wks now! and really do recommend at least a month a plate (trial time). Anyway i,m glad everyone with these kits are using the whole range of sizes to find what the optimum is for there own vehicle . Anybody got anymore up to date( hole size .vs. mpg) 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
31st May 2010 8:24pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Going to put 14mm on mine now as run with 18mm for a few weeks now ....MPG has gone up a bit and sounds quieter.... Getting 270 miles out of a tank full right to the brim and light came on at that... but i have got roof rack on and 305s can somebody work out what MPG i'm getting... Cheers NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
31st May 2010 9:28pm |
karlos if your only doing 270 miles to the tank full your mpg is about 17 to the gallon!!!! 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
31st May 2010 9:59pm |
Cheers bud.....That's not really much is it and that was driving at about 65/70 all the way NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
31st May 2010 10:10pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I don't know if there's a difference in volume between 90 and 110 tanks, but on my 90 when the fuel warning light comes on I can fit in 48 litres (or 10.55 gallons) until it's full. Doing 270 miles on 48 litres gives you around 25.6 mpg. I expect to see my light come on around 280, so it's in line with what I'd expect given the roof-rack Peter
2008 SWB Truck Cab 1952 80" Soft top |
31st May 2010 10:27pm |
Cheers Pete it is a 90...and that makes me feel better at 25 mpg NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
31st May 2010 10:33pm |
That does sound much better!!! I drive a 110 and the tank holds 75liters so I just did the calculation by that, thanks for the correction mr flips. 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
1st Jun 2010 12:55pm |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 |
waiting for my set to arrive and then i'll start on the testing (thanks Robofarmer)
i just have to hope i can follow the pics and instructions in the thread to fit the damm thing Puma 2.2 90 Stationwagon |
1st Jun 2010 4:03pm |
All you need is on page 3 of this thread. They don't get any clearer. A couple of times and you'll have it down to no longer than 10 - 15 minutes I assure you! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Jun 2010 5:28pm |
Robofarmer,
My blanking plates arrived this morning. Thanks Now to fit one and test it out. Thanks Daz110 |
2nd Jun 2010 9:22am |
