![]() | Home > Tdi > 300Tdi Oil. |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Tesco were doing Castrol 15W 40 x 2 litres last week at £6 - half price. I cleared the shelf
![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85 ![]() ![]() ![]() |
Castrol Magnetec 10W/40 semi-synthetic is the closest oil to the stuff that the Tdi was developed on. I always use it in my 300Tdi, as I have had the vehicle from almost-new, given that it doesn't use more than 100ml between services. The Fuchs Titan 10W/40 seems to be good oil, not a bad price, and that is what I put into my customer's cars for their services where that grade is required (except the Landrovers, they get Castrol as a special treat!) Roads? Where we're going, we don't need roads.
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
Wilkinsons 10w 40 semi, 5LTS, good stuff, £14.50 (5 ltrs not 4.55 ltrs be careful!)
Rob Member Since: 04 Sep 2012 Location: Brownhills Posts: 40 ![]() ![]() ![]() |
Always 15w40, NOT 10w40 especially if the tdi has a few thousands miles under its belt......
Ohlins Member Since: 20 Oct 2009 Location: French Pyrénées Posts: 28 ![]() ![]() |
400,000kms...doesn't use oil between each 5k oil change...10W40 Semi Syth..
Just say'in... ![]() . Army 110 3 Door 200tdi Army 110 3 Door V8 Army Lightweight 2.25 Petrol 110 300tdi 5 door Yamaha XT660Z Ténéré Gas Gas 300EC Ohlins |
tdi-rick Member Since: 15 Aug 2007 Location: Oz Posts: 2 ![]() ![]() |
Hmm, you really don't understand the SAE oil viscosity numbers, do you ? ![]() Any xW-40 diesel oil that meets/exceeds API CI-4+ and/or ACEA E4/6/9 is a good choice, in other words any 5W/10W/15W-40 HDEO. |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Will be getting some magnatec to do mine next weekend ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
