![]() | Home > Tdi > 300Tdi Oil. |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Always ran mine on 5w30 semi synthetic,Bought it at 103,000 kept it till 160,000 (well it went walkabout actually).Never had any issues. 2005 Td5 90 XS
Steve |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I run my 300tdi on 10W40 Semi Synth (Fuchs Titan) and it seems fine as well as this is what is listed in the manual so should be ok. I think dropping to a 5W30 is ok too and may improve mpg etc.
10W40 Part Synthetic.
Can go for the most expensive magnitech but its equally as happy on the cheap halfruads stuff. Before you change give it a run with a tin of engine flush in it till it’s warm, then drop the old oil while it’s still a bit warm (it will look like a mix of oil and coal dust which is normal) remember to replace the sump sealing washer and oil filter then refill with new oil. Up to you but I always add in a tin of Wynns oil treatment when I change as I feel it makes a difference to my engine's running but again, up to you. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
I think Halfords are running an offer where all their oil is £10.
I recommend fitting a Drainplug to replace your sump plug, makes draining the oil so much easier. I got mine form Difflock... http://www.difflock.com/drainplug/ |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
My 300TDi was filled with Magnatec by the main dealer at the initial 1K mile service and I have used the same stuff every 6-months since.
They also stripped the drain-plug at said service so I fitted a Difflock Drainplug the next time (wasn't letting them near it again) and it has worked fine for all these years. ONE LIFE, GET IT! |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Whatever costco are flogging! Big drum (20l or so) for the price of one bottle from usual shops. Think it's 10w40
Being a tdi, it will probably run on anything. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2724 ![]() ![]() |
I just use 10w/40 or 15w/40 semi-synthetic - whatever I can get hold of cheapest at the time.
If you look in the handbook it actually tells you what fluids to put in and when ![]() |
I popped into Halfords this morning as I needed a few bits and had a look at this oil. It is not their usual oil that is on sale, it is a 'special purchase' product. It is in 4L containers rather than their usual 5L and seems to be a cheap generic oil (petrol or diesel). The Halfords 10W40 turbo diesel specific oil is £17.99 for 5L.
I think I will stick with Fuchs Titan which I can get for about £18 for 5L from Opie as that is good quality stuff and not much more than Halfords. |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
Try Morris c three 10/40 I find it very good
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
There is a discount at Opie for Defender2 members
djgg Member Since: 22 Apr 2013 Location: Southport Posts: 22 ![]() ![]() |
Thank you all for your advice, one more question. I have 10ltrs of 15W40 multi purpose oil would this be ok to use? or do I need to buy some semi-synthetic oil?
David. |
Personally I would stick to a decent 10W40 rather than use up the stuff you already have, however tempting it is to save cash. However that is just me 'like things to be right' rather than a technical expert opinion.
I think your right, decent 10W40 it is then, but it was worth asking. David |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Fuchs 10/40 Semi i run in my tgv's Cheers
