Home > Maintenance & Modifications > Shaggydogs Running Restoration |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
Hey Shaggy,
Talks cheap and all, but it almost sounds like you've come to a reasonable conclusion. Nothing lives forever and you have to make your own mind up if the 110 is worth saving-in your circumstances. I had to do the same with a previous 90 and cut my losses. Other fcorum members may and probably will suggest different but if it makes financial sense sell it and buy something newer thats going to do your jobas long as it's a Defender Best of luck, Steve |
11th Apr 2014 11:29pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Hmm think if it was me I would be looking for something newer,
There are plenty out there ! My 109 thread my youtube channel Last edited by g-mack on 2nd Nov 2016 1:47pm. Edited 1 time in total |
11th Apr 2014 11:54pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
I did a complete rechassis in my neighbours drive, and then very recently changed my clutch in my drive,no sign of any cover at all. My whole chassis change, including new bulkhead, chassis, suspension, brakes, and loads of other shiny bits came in around £2700, just wait a few weeks for the weather to improve, i'm sure its better than what we have up here 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
12th Apr 2014 6:04am |
Is there anything not needing a little TLC and a fat wallet?
**Edit** Forgot sorry....
I had a Discovery in a similar condition to what you describe above, every time you think you've got it sorted something else creeps up on you and it becomes a 'money pit' consuming more and more of your time and money whilst frustration levels rocket skywards. Get shot and enjoy the Summer would be my own personal advice or you'll be spending most of it up to your proverbials in oil and grease under your truck without a penny to scratch you're ar53 with. Keep the filaments as well for on your next truck, they may not be quite so reliable! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Apr 2014 6:34am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Thanks for comments guys.
Thing is, engine runs beautifully, gearbox and transfer box have no backlash, bit of wear in the half shafts but its what I'd expect its not bad enough to replace yet. And as K9F has pointed out- lights all work perfectly The injector knock seems to have cured itself today so will just keep an ear out for it, hopefully just a bit of crap got past the fuel filter but all is working now. As I say, mechanically she is spot on. Have decided against selling, can't find a nice enough 130 to tear me away from her within budget. I think its worth the investment just need more time to shop around and get some quotes. Speaking to a friend who works for jaguar he agreed that £1047 for a clutch and rear oil seal was far too much money for a TDI so is going to see what he can do. Someone has suggested putting some of this in the diff and seeing if it makes any difference http://www.halfords.com/webapp/wcs/stores/...yId_255220 Anyone got any experiance? As for the welding, well, can only shop around more and see what's best on offer. Its not all doom and gloom |
12th Apr 2014 9:37pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Never tried that stuff, so couldn't comment.
As for the prices you were quoting in your first post, seems like you were going to a Rolls Royce dealer?! Regarding a potential new vehicle - better the devil you know? I don't think that many 130s come up, certainly not cheap ones (unless they're cheap for a reason). The bulkhead: it appears that it is fairly terminal - I would agree that a galv replacement would be better. Ashtree are v expensive, and I have heard mixed reviews historically. There is a chap on various forums, by the name of ghound. He is based in Ireland and repairs and galvs bulkheads and sells them on ebay - his work is excellent and I think I paid about £500 for mine, delivered. Replacing it yourself isn't especially difficult, just time consuming. I can see how you would want someone else to do it. Clutch: as you say, the kit is about £50 for an AP one. I have changed mine before by taking the gearbox out with the help of a couple of scaffold poles. not too difficult a job overall - probably a day's work for a novice with poles rather than a crane. Might even get away with using a jack and a helper. Diff: spend the fiver on a new seal and give it a go yourself. Alternately, if you have a mate with a suitable press, rebuild the diff for the £30 odd it will cost for the bearings and seals. |
15th Apr 2014 2:20pm |
I have definitely decided against selling up (unless the exact spec 130 right down to colour pops up) for many reasons but I feel that the rest of the vehicle is good enough to warrant the work!
Have been ringing and emailing around today again and have still been getting same sort of quotes of £1000+ so more I'm thinking its going to be about £2k all in. Here is the damage Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Would love to do a galvanised replacement and to be honest am more than capable of doing it myself as it would just be unbolting and rebuilding and would probably take a lot more time getting it right, filling with cavity wax, soundproofing, painting, than anyone else would. Unfortunately its my only means of transport so has to be done fairly quick and I haven't got the workshop space to do it. Speaking to an independent today they said that in order to fit a 130 clutch to a 110 they would also have to change the flywheel which would be about £400 worth of parts which I thought was a bit excessive! Does anyone know of a good supplier for a 200tdi clutch kit? Suppose would make sense to fit a 110 clutch but have heard that 130 clutches are much heaver duty and last much longer- given the bother this has caused would rather fit and forget for the next few years! But is this justified I'm beginning to ask? I know the HD clutch is heavier but everyone who has ever driven my 110 has commented on how much heavier than normal it is so the weight isn't an issue to me at all. |
15th Apr 2014 7:07pm |
I got my clutch (for a 90 admittedly) from Paddocks (sorry) for around £60. I know a fair few people do put the 130 clutch in, but I saw no need myself.
the pass. side bulkhead looks like rust held together with paint! |
16th Apr 2014 9:08am |
Update time!
Latest quote for the welding has come in at £1180+Vat. Had a long chat with them and they explained how the dash would have to come out, the passenger wing would have to come out, the roof would have to come off. After that would need to be cut out, new patch worked in, would then need to be filled, sanded, stopped, primed, painted, after which would then need to reassemble wing replacing any broken fittings, reassemble the dash, refit the roof and reseal it. Quite a lot of work when considering your battling against 22 year old fixings and fittings. Looking at the quality of there work (I was stood next to a very nice 110 and he turned and said this is one which has been done by us and honestly I could not see the repair and I was looking for it!) I am very impressed and would be happy to have it done there. He added that for roughly £2000 all in, could do the conversion from CSW to USW which is something I have wanted to do for a while. Reason being the roof is off anyway and would mean all could be done sealed in together which should eliminate any leaks. What do we reckon? |
16th Apr 2014 10:06pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
Glad you're keeping your "old friend".
It appears that you're going to spend some serious dollars,....which probably should have been spent gradually, over the years, as the issues arose? Anyway, maybe you can't do this stuff all at once, my only suggestion is, even if it does cost a few dollars, do each job properly when you do it, then you won't ever have to worry about that part again. I'm pretty hopeless at mechanical stuff myself, so I always have to pay to get stuff done, ...and I don't mind paying, as long as the job's done right. Cheers, Pickles. |
16th Apr 2014 10:11pm |
Hello all!
had a bit of a further poke and prod today and to my shock found the bulkhead has got rot fairly well set in behind the dash panels Its weird, the foot wells, A-posts are the most prone to rust yet it has rotted at the top of the bulkhead and behind the dashboard! So it is pretty much beyond economic repair as to repair all the rot would have to cut the top of the Bulkhead from the top of the foot wells up off and make new at which point you may as well just get a new one. So, this leaves me with a headache... where can I find a rot free 200Tdi bulkhead for reasonable money. Have had a scout around and most of them seem to be re-manufactured- this worry me because potentially there is rot still within them so would do the same thing leaving me back at square 1. One option I have thought of is should I look at Equicar or similar and get a complete TDCI bulkhead and bodge it to fit a TDI so you have TDCI dash and bulkhead- but in a Tdi. Any Suggestions? (or offers of a rot free bulkhead ) |
24th May 2014 4:47pm |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
Shaggydog a friend of mine has a very good bulkhead complete with dash which has td5 clocks in. It was scheduled to be fitted to a 110 but Gary her husband died .Sue is away at the moment I'll give her a call tonight if you are interested. Sue sold her 110 so it's now in her way.
Uncas |
25th May 2014 9:06am |
Uncas- Would be interested, I need to have a chat with the guys who will be doing the work if they are going to supply the bulkhead or if I need to source it, in which case I would be very interested if it is in good condition.
On the brighter side of things went around and topped up all the oils but was pleased to find that most only needed a dribble. Apart from the gearbox which needed about half a litre worryingly. |
26th May 2014 11:03am |
Changing a bulkhead isn't a fun job and certainly not one you want to do more than once - get a galvanised one.
27th May 2014 3:21pm |
