Home > Td5 > ECU part number MSB101181
GreigP
Scotland 1999 Defender 90 2.5 TD CSW Oslo Blue
Hi Guys,
I have been doing my heed in googling and reading through a number of threads on the old "temperature gauge working in reverse". I had initially replaced the sensor hoping for a quick win, but I guess that was wishful thinking.. Crying or Very sad
I have a 1999 defender 90 Td5 and it looks to me as if I might have a non flashable Discovery ECU type...which I'm guessing wasn't in there by default.. does anyone know if that's right??
I also get the jerky performance at low speeds etc ( which I was relieved it wasn't just my bad driving), but it certainly pulls well etc and I'm not aware of any other issues (at the moment) Neutral
Am I looking at a new ECU? Big Cry Or can I just live with it as is ( assuming it doesn't actually overheat Wink )
If it is new ecu....any recomendations?
again, thanks in advance for any advice.
Greig
PS planning to get her remapped etc this year so maybe that means new ECU anyway
Post #332789 22nd May 2014 4:16pm
Yup, this is exactly what you've got.
When i built the project90-3 (in the "my defender" forum) my engine was ex disco, so I used the ECU just to get me going. Eventually I found a flashable type, and the transformation was unbelievable.
I agree, the throttle is so jerky when using the disco ECU/tune on a defender.
So, if you plan to re-map it at a later date, you will need either an NNN500020 or an NNN000120 or maybe an NNN000250, but I'm not 100% sure about that last one.
With the others, just get a nanocom or similar ECu tuning tool, dump the relavent defender Td5 file to it (depending on what type of engine you've got), and enjoy the nice driving style!!
Post #332849 22nd May 2014 8:15pm
GreigP
Hey diesel_jim.......perfect guv.....it was actually your thread that made the penny drop, but I didn't want to post on it as it looked dormant now..
I did see elsewhere a list of ECU numbers for defenders and discos but didn't see my specific one mentioned....
I am am planning to pay a visit to IRB sometime this year so I can check out with the guys what my options are..
thanks again for your input guv...
I'm guessing there is no real issue driving it like this as long as it doesn't actually overheat Shocked
cheers,
G
Post #332855 22nd May 2014 8:34pm
excossack
If its any help, mine is jerky at low speeds as well.(mine is the same year as yours) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #332872 22nd May 2014 9:30pm
GreigP
ah ok......no worries...I guess you have the temp sensor issue too then...?
Post #332879 22nd May 2014 9:54pm
GreigP
ah ok......no worries... thanks excossack Smile I guess you have the temp sensor issue too then...?
are you planing to change ECU it or just living with it ?
Post #332881 22nd May 2014 9:55pm
excossack
I didn't swap the ECU. Its the standard TD5 110 one 1999 Defender TD5 110
Regards
John M0VAZ
Post #332882 22nd May 2014 10:04pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I had a problem with my temperature gauge going backwards on my 05 TD5, turned out to be a bad earth to the ECU, run a new earth cable to the ECU and cleaned up the original connections and it was fine.
Hope yours is simpler than ECU swaps. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #332907 22nd May 2014 11:18pm
GreigP
yeah I think I'll try the earth cable..just in case...plus its cheap n easy..
But guessing that if the MSB101181 is a Disco ECU then i'm probably stuffed anyway..
however, thanks for the input Thumbs Up
Post #332973 23rd May 2014 10:10am
GreigP
Tried running a new earth cable from one of the ECU mount bolts directly to the battery.....no joy I'm afraid.. Crying or Very sad
was worth a try anyway..
Post #332981 23rd May 2014 10:50am
That MSB part number is definately an discovery unit, so all the eaths in the world aren't going to make it run "correctly"
Excossack.... there's jerkyness and then there's jerkyness.... with the disco ECU it is really bad.
Post #333089 23rd May 2014 8:35pm
excossack
I think I just have the first level of jerkyness with a Defender ECU! 1999 Defender TD5 110
Regards
John M0VAZ
Post #333091 23rd May 2014 8:36pm
I think early Td5's were quite jerky in that respect.
Post #333092 23rd May 2014 8:43pm
GreigP
diesel_jim wrote:
That MSB part number is definately an discovery unit, so all the eaths in the world aren't going to make it run "correctly" .
Thumbs Up
yeah I have now "gotten over this" Razz and am now googling the difference between the NNN500020 or an NNN000120 ( my current thoughts are the NNN000120 ... and a shiny nanocom evo too Embarassed ( love my gadgets)
Shiny new bits, and a remap are a definite Cool
thanks again diesel_jim
Post #333099 23rd May 2014 9:03pm
excossack
I would prefer it if mine wasn't! 1999 Defender TD5 110
Regards
John M0VAZ
Post #333172 24th May 2014 9:39am
