Home > For Sale & Wanted > [For Sale]Provent 200, 1 left.
Page 7 of 9 <123456789>
landy andy
Ohh. I like. What's the part no. And price please.
Andy
Post #332271 20th May 2014 12:39pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Considering how much oil tdis tend to have in the air box, I can't see it doing much!
Post #332280 20th May 2014 1:04pm
LR90XS2011
ERR1471 about £12 if you shop around.
I can not yet recommend this as I'm trialing it at the moment. I got the idea of a Mitsubushi L200 forum. I will post how the trial goes after a few thousand miles, it will not be as effective as the Provent as it is a simple device with no filter but it is cheap and fairly small and may well remove some of the oil that normally passes to the intake, also my landy is very low miles so may not be passing much oil yet anyway. I did have a Provent but didnt fit it due to space constraints, they are clearly quality bits of kit, but I sold it to K9F as space was so tight and he wanted one. Thought Id give this a go.
re 200tdis having oil in the air box they may well have some oil get to the air box but may have much more without this?
all the best Rob DEFENDER 90 TDCI XS,
Post #332285 20th May 2014 1:16pm
landy andy
May get a Tdi one for mine. Looks nice and simple, and was amazed at the oil dripping from the breather pipe when I pulled it out my air box the other day. I certainly can't see it doing any harm.
Andy
Post #332403 20th May 2014 7:33pm
LR90XS2011
well after driving about 50 miles locally I thought the 200tdi one was naff as nothing had appeared in my drain tube!.
However yesterday I did a 220 mile round trip to Wales and back and I can confirm that there is about 8-10 mm of oil appeared in the bottom of my drain off tube (I used 8mm ID clear plastic pipe for a very short drain off pipe). This confirms that the 200tdi separator does work. Clearly I have no idea how much oil is still passing into the inlet hose but I have stopped some.
When I get a chance I will replace that short plastic pipe with a longer length of rubber pipe going down towards the chassis and will confirm the results over a longer trial. Full cost of mod about £20 so far. DEFENDER 90 TDCI XS,
Post #333221 24th May 2014 1:13pm
shaggydog
all the best Rob
The reason Tdi's sometimes have oil in the air box is because the separator gets gunked up and doesn't separate the oil as efficiently so it condenses in the pipe and drips down into the air box because the breather intake comes in at the top. When the engine isn't running and it cools it just drips down into the air box.
I always flush mine out when I do my 12000 mile service so just dump some petrol through it to clean it then blow it through. I never have more than a slight haze of oil in mine.
Without the separator it would be much worse.
Post #333226 24th May 2014 1:39pm
LR90XS2011
Excellent sounds like this may be a worthwhile mod then, I will continue to monitor how mine performs on a TDCI.
Diablo perhaps your needs a clean as ShaggyDog suggests!! DEFENDER 90 TDCI XS,
Post #333228 24th May 2014 1:45pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I have one more 'Provent' which I will sell, I was keeping this as my spare but have my eye on some new Mountain Bike wheels and as we have a little one now I have to sell something to raise the funds Very Happy
Exactly the same part as described in the original post £100 delivered to mainland UK (I will ship to Highlands/Islands for a little extra)
Regards,
Steve
Post #367486 27th Oct 2014 12:50pm
landy andy
Yes please.
Andy
Post #367490 27th Oct 2014 1:09pm
Steve B
Hi Andy,
PM sent
Steve
Post #367508 27th Oct 2014 2:10pm
landy andy
Replied and paid. Thumbs Up
Andy
Post #367510 27th Oct 2014 2:23pm
K9F
Landy Andy you may struggle fitting with an XS have a look at my fitting process as available space is extremely tight in an XS.
I bought mine off of a member who struggled to find space on his. From page 4 to 5 this thread.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #367551 27th Oct 2014 5:25pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Are these all sold?
Sorry to ask but I want to do this mod to my 2006 Td5, it's in great nick at the moment and I want to keep it that way, if I buy a Provent, what other 'bits' will I need to fit it, are the pipework and reducers easy to get hold of?
Post #367556 27th Oct 2014 5:55pm
landy andy
Thanks K9F Thumbs Up
And
Lambley, watch this space, there may be one for sale soon if K9F is correct. Big Cry Big Cry
Andy
Post #367565 27th Oct 2014 6:19pm
Lambley
Ok, thanks Andy, first dibs and all that!
Post #367566 27th Oct 2014 6:28pm
