Home > For Sale & Wanted > [For Sale]Provent 200, 1 left.
Page 6 of 9 <123456789>
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
Re: Final Install.
K9F wrote:
Done and dusted. Didn't have to use stainless jubillee clips as pressure release valve operates before pipes would become dislodged but thought it the prudent thing to do.
Hey Mal,
sorry I been away so long - work - too boring to discuss.
Hey, that looks like a blooming masterpiece mate! Well done!!!
Are you at least pleased you have the filter working now? ****CENSORED****
Post #328939 7th May 2014 10:36am
K9F
Yes I am pleased. It has a good functionality I think and I missed the first run on these. Have been out for a couple of blasts and it needed a little fettliing and slight movement of the mounting bracket as the drainage outlet was a little too close for comfort to the turbo for my liking. All sorted now. Thank you for your help and advice on this one!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #328989 7th May 2014 1:42pm
RockJaw
That's what mine looks like Mal - far from any of the really hot stuff and well away from anything too mischievous
Did you put a tap on yours? ****CENSORED****
Post #329266 8th May 2014 12:18pm
K9F
Not yet Rockjaw just an M10 bolt and a small jubillee at the moment. Can't see me having to drain it too regularly. Keep popping the lid, lifting the filter and looking inside with mounting excitement and don't see anything.
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329422 8th May 2014 7:34pm
RockJaw
We don't drain ours more than once every 20k-30k (kms that is, not miles) ****CENSORED****
Post #329537 9th May 2014 6:12am
K9F
As it's a hobby the mileage I cover I'll need a mobility scooter and a hoist to drain mine when needed. Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329553 9th May 2014 7:24am
munch90
is it really worth the extra fitting if you only drain it that much , it must mean the filter and valve fitted as standard are enough
still we like our extra gadgets and gizmos
Post #329571 9th May 2014 8:43am
LR90XS2011
Mal
Im pleased it worked out, Ive ordered a 200tdi one as per my previous post and although clearly not as functional as the provent im hoping it will give me simular protection, will post how I get on
all the best Rob
 DEFENDER 90 TDCI XS,
Post #329574 9th May 2014 8:50am
RockJaw
Point taken, but the tap is quite invisible and hardly a gadget or gizmo. Installing the tap just finishes the job nicely.
You are 100% right though, it really isn't necessary. ****CENSORED****
Post #329589 9th May 2014 9:49am
munch90
I mean the whole thing is it really worth fitting , if it only needs draining every 20-30k
Post #329597 9th May 2014 10:19am
K9F
Munch I don't really know but filtered air must be better than unfiltered surely? Disconnect your crankcase breather on your Defender (either end) and stick your pinkie in the pipe. I was surprised how much crud must pass through it. On a larger scale on the vessels I work on the turbos and filters are removed every 12 months to decarbonise them due to the oil mist being fed back into them from the crankcase breathers, nevertheless we are talking over a ton of oil in each engine by weight. Glad I did the modification it can't do any harm as it's a long-term keeper.
There's some blurb here that claims how it protects the turbo and downstream components.....
https://www.mann-hummel.com/fileadmin/user...n_2013.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329635 9th May 2014 1:03pm
munch90
no cant do any harm
what about having the extra valve would there be any possible over pressure problems with running two valves
Post #329638 9th May 2014 1:08pm
RockJaw
We run dozens of these things on 4 continents, plus all the other diesel operated gear we deploy and trust me, there is a big difference between those diesel motors fitted with Provents and those without.
Sure, you won't see much difference in the first 5 - 10k miles, but when you pull a 50k or 100k apart, you will be glad you had one of these fitted. ****CENSORED****
Post #329648 9th May 2014 1:35pm
LR90XS2011
photo of 200tdi separator temporarily fitted to see if it catches anything, clearly not as clever a bit of kit as the provent but cheap as chips
Post #332240 20th May 2014 9:56am
K9F
Similar position to mine. Being somewhat smaller in size I would imagine it didn't take long to fit. Nice modification that time will tell if there's any benefits to be reaped. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332244 20th May 2014 10:18am
