![]() | Home > Td5 > Wheres my fuel going? |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
could have a good few reasons and some add a bit here and there = to a good few miles less to the gallon .
But as said diameter in tyres will vary you miles clocked . I would also have a look at the diesel , ie are you buying at the same place most times ? If so change and see ... Also in the winter the mix in the diesel is changed re frost , leading to a lesser effeciency of the diesel . Postmanpat |
Stoo Member Since: 20 Aug 2009 Location: Maidstone, Kent Posts: 37 ![]() ![]() |
Noticed sluggish performance and substantial fuel economy drop (4-5MPG) recently. Diagnosed replacement MAF by disconnecting it and noticing significant performance gains.
I haven't been far enough to see if the fuel economy has improved, but it is possible that this is the same problem. Stoo ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Think summer winter fuel consumption is evened out by the need for all the electrical kit during the winter. (Headlights, heater, fan etc. )
Andy |
Ellis01 Member Since: 16 Nov 2012 Location: Durham Posts: 14 ![]() ![]() |
Random but easy to check - make sure your fuel pressure regulator isn't leaking
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 ![]() ![]() ![]() |
As an update I was offered a full face allard intercooler cheap so took the opurtinity, and my mpg instantly jumped to 28mpg and more power
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 ![]() ![]() ![]() |
So.. just thought I'd check mine, 2005 90
... a week or 3 commuting 10k to and from work, then over the Alps and thro San Bernadino and down to Tuscany, some tracks down there on a friends property, back over the alps, an 'ab gas' (exhaust ) test - at 4800 rpm !! , (long story, getting it registered in Switzerland) a bit more commuting. all in all - what a Landy is for really. 941 miles (assuming it's correct), 148l. 29 mpg if my finger are right. ![]() Brought the 90 home from Switzerland ... |
