Home > Td5 > Wheres my fuel going? |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 |
could have a good few reasons and some add a bit here and there = to a good few miles less to the gallon .
But as said diameter in tyres will vary you miles clocked . I would also have a look at the diesel , ie are you buying at the same place most times ? If so change and see ... Also in the winter the mix in the diesel is changed re frost , leading to a lesser effeciency of the diesel . Postmanpat |
28th Feb 2014 2:11pm |
Stoo Member Since: 20 Aug 2009 Location: Maidstone, Kent Posts: 37 |
Noticed sluggish performance and substantial fuel economy drop (4-5MPG) recently. Diagnosed replacement MAF by disconnecting it and noticing significant performance gains.
I haven't been far enough to see if the fuel economy has improved, but it is possible that this is the same problem. Stoo |
28th Feb 2014 2:45pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5568 |
Think summer winter fuel consumption is evened out by the need for all the electrical kit during the winter. (Headlights, heater, fan etc. )
Andy |
28th Feb 2014 4:40pm |
Ellis01 Member Since: 16 Nov 2012 Location: Durham Posts: 14 |
Random but easy to check - make sure your fuel pressure regulator isn't leaking
19th Mar 2014 4:40pm |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 |
As an update I was offered a full face allard intercooler cheap so took the opurtinity, and my mpg instantly jumped to 28mpg and more power
22nd Mar 2014 10:23am |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
So.. just thought I'd check mine, 2005 90
... a week or 3 commuting 10k to and from work, then over the Alps and thro San Bernadino and down to Tuscany, some tracks down there on a friends property, back over the alps, an 'ab gas' (exhaust ) test - at 4800 rpm !! , (long story, getting it registered in Switzerland) a bit more commuting. all in all - what a Landy is for really. 941 miles (assuming it's correct), 148l. 29 mpg if my finger are right. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
19th May 2014 10:12pm |
