Home > Wheels & Tyres > 285 |
Only 'posh' bearings for me! I wouldn't consider fitting any bearing under £14:99! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th May 2010 9:02pm |
I forgot.....'Bearing' in mind most things are cheaper up North.....Doh!!!! If you go through life with your head in the sand....all people will see is an ar5e!!
28th May 2010 7:16am |
