Home > Maintenance & Modifications > Stainless steel EGR blanking kits |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2047 |
Any more news regarding EGR blanking plates?
MPG, more power, quietness, smoothness, etc? Thanks Daz110 |
22nd May 2010 8:44am |
Daz,
there's been lots happening over the last couple of weeks! Read the recent posts on this thread! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd May 2010 10:33am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Put mine on this evening. Took about 10 minutes to undo all the bolts and get the studs out. Took about another 10 minuts to put the new plate (the second largest) in and the top bolt. Then an hour and a half to put the bottom one in
Took it out for a short 10 mile drive, TBH felt the same and there was no apparent difference in the way it drove. If over the next week or so I notice any impovements I will of course update this thread. I stopped off and filled the tank to the brim so i will report back on how I think the mpg is. Boy |
23rd May 2010 7:38pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
well the mpg is up by about 20-30 mile per tank and im on the 14mm hole with no light in sight
2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th May 2010 4:47pm |
Exactly the same for me too with the 16mm blank fitted! I just got 31.6 mpg out of my last tankfull! Never achieved anywhere near that before fitting the blanks! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th May 2010 10:04pm |
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 |
Thats good to here guys My mpg over the last few months has gone up and up with the plates in from around 21.5 upto the last tank which was pulling a sankey back from grantham and not holding( petes tuned horses back!!) and got 29!mpg I must say the bigger intercooler i think is helping me to. 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
27th May 2010 6:26am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
I'm assuming that all of you who fitted the blanking plates are no longer under warranty?
27th May 2010 7:39am |
All this news sounds great.
When my Defender runs out of warranty next month then it looks like this will be the first job to do. Looks like mine already has the bolts fitted instead of studs. Where do you get the blanking plates from? I'm thinking of an ITG air filter to go with the blanking plate? Thanks Daz110 |
27th May 2010 7:41am |
Robofarmer, you still got those blanking kits available?....and how much are they?
Thanks Daz110 |
27th May 2010 7:48am |
. Why wait for the end of warrenty ?. I have 12 months left on mine the plates a really easy to put in and out within 20mins!. Just carry what you need to revert to normal just in case. All you need is a 13mm spanner ,13mm socket and a pair of small grips. Job done 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
27th May 2010 7:50am |
Why are you concerned about other people's warranty???? It's their choice. Same goes for remaps and a myriad of other modifications....
Good choice I had one fitted prior to the blanks. If you've not got a snorkel you get a nice induction 'growl' with the new filter fitted from the intake at a certain RPM. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 27th May 2010 8:00am. Edited 1 time in total |
27th May 2010 7:55am |
Sounds good....Ok, how much are they?
Daz110 |
27th May 2010 7:56am |
yes daz I have a few left! Or pete at Bas will have them on his stand at 2010 southwest landrover show 2008 110 County utility ex 1988 defender 90 ,td ex 1970 series III |
27th May 2010 7:57am |
Robofarmer, is the price top secret?
Daz110 |
27th May 2010 8:02am |
