Home > Puma (Tdci) > Interior light
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Interior light
Latterly I've noticed my interior light don't come on when doors are open even when I unlock from the fob the light quickly flashes like a camera flash then out all fuses are ok have checked all door pins seems I may have a fault with the 10aS alarm ecu I know it supply's a earth path through the. 10AS but don't want to fork out for a new one if it isn't that noticed plenty of disco 10 AS on eBay thing is will they still work on the Puma or is the wiring on the plugs different I know I need one with CCL built in btw my alarm is working ok just the interior light playing up which seems to be common but it does light up on the on position but not in remote the nanocom settings are smart and welcome is enabled also do you think if I disconnected the battery for 10 mins it may reset the 10as trouble is my nanocom has been Rma back to cypress frightened that I may lose synch with the fobs and no nanocom to reset them till I get it back
Post #326220 26th Apr 2014 1:52pm
110 John
Sorted with the Nanocom it was the settings incorrect
Post #330221 11th May 2014 1:12pm
