Home > Maintenance & Modifications > Puma glove box
Page 2 of 4 <1234>
leeds
Most of the retro fit glove boxes do not have a positive latching system.
We can supply a lockable version at £95 if required.
Brendan
Post #323090 11th Apr 2014 2:25pm
chris bb
England 1998 Defender 90 300 Tdi ST Nato Green
Go Beyond wrote:
Have you used original screws to fix hinge down ?
Yes, which I think may be part of the problem, the heads stick up quite proud.
Temporary fix, Araldite a thin "super" magnet to the inside of the lid, it sticks to the metal bottom plate. Series 2A 88, 1976 - 1980
Series 3 Lightweight, 1999 - 2011
200 TDi 90, 2012 - 2014
Puma 90, 2015
Wolf 90, 2017 -
Post #323099 11th Apr 2014 3:01pm
It is the problem, don't use the original bolts, use flatter self tappers or countersunk bolts with nuts
Post #323101 11th Apr 2014 3:07pm
chris bb
Thanks for that. I've looked at the lid and think that it' not just the bolt head; the whole lid is raised up too far by the hinge and the way it all doesn't quite fit into the original casting.
My "temporary" fix of a super magnet is now permanent and works very well.
I really can't believe that LR didn't fit this as standard, presumably just to save a couple of quid.
Whilst I had the Araldite out I also fixed the passenger door rubber strip where it meets the top of the door.
Hey-ho, I never had such "fun" whilst owning Subarus & Fords. Series 2A 88, 1976 - 1980
Puma 90, 2015
Wolf 90, 2017 -
Post #323160 11th Apr 2014 8:09pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I fitted my glove box yesterday -but it took a lot of work to get it to fit the way I was happy with it.
Most pictures I've seen show the dash top sitting awkwardly and I wanted to get a fit that was more like it was before the mod.
Details here: http://defender90xs.blogspot.co.uk/2014/05...ation.html http://defender90xs.blogspot.co.uk/
Post #328033 3rd May 2014 1:37pm
Jim_Bean
I've got the same problem with the lid not shutting properly Crying or Very sad
What size are the original bolts? What do i need to buy in order to get it to close flush?
Post #329440 8th May 2014 8:21pm
bear100
+1 for mobile storage systems, great easy to install piece of kit
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #329443 8th May 2014 8:26pm
Jim_Bean
Its a great bit of kit but i wish it was supplied with black fixings and two new flush bolts to replace the originals and allow the lid to close flush with the dash Crying or Very sad
Other than the fixings the quality is great.
Post #329446 8th May 2014 8:28pm
chris bb
Jim,
Even with flush bolts it doesn't shut flush due to the thickness of the hinge. Flush bolts help as does the thin super magnet I used. Series 2A 88, 1976 - 1980
Puma 90, 2015
Wolf 90, 2017 -
Post #329447 8th May 2014 8:31pm
Jim_Bean
mark_d i really want to get the same result as you - looks superb Bow down
What fixings are those on the dash?
Mine just doesn't sit right
Post #329448 8th May 2014 8:33pm
Jim_Bean
Hi Chris - i'm hoping i can get it a bit lower tho. Failing that i'll have to use some foam sealing tape - bit naff though Shocked
Post #329450 8th May 2014 8:34pm
Jim_Bean
Chris - do you remember what size the original bolts were?
Post #329455 8th May 2014 8:40pm
munch90
the britpart one fits much lower than that one in the pic , and looks the same design as the nak one
and if you fit it just right they sort of clip over the bottom edge
Post #329458 8th May 2014 8:47pm
Jim_Bean
Well i'm kind of stuck with the Mobile Storage one now. I'm hoping a change of fixings is all it needs.
Post #329462 8th May 2014 8:54pm
chris bb
Jim, no I just used some recessed head screws from my "they'll come in useful one day" drawer. They chewed their way into the plastic thing that secured the original self tappers. Unfortunately I'm a brute force & ignorance type of engineer, plenty of the former, not too much of the latter. Series 2A 88, 1976 - 1980
Puma 90, 2015
Wolf 90, 2017 -
Post #329509 8th May 2014 11:00pm
Page 2 of 4 <1234>
