Home > Maintenance & Modifications > Puma glove box |
chris bb Member Since: 14 Feb 2014 Location: South Hampshire Posts: 28 |
Yes, which I think may be part of the problem, the heads stick up quite proud. Temporary fix, Araldite a thin "super" magnet to the inside of the lid, it sticks to the metal bottom plate. Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
11th Apr 2014 3:01pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
It is the problem, don't use the original bolts, use flatter self tappers or countersunk bolts with nuts
11th Apr 2014 3:07pm |
Thanks for that. I've looked at the lid and think that it' not just the bolt head; the whole lid is raised up too far by the hinge and the way it all doesn't quite fit into the original casting.
My "temporary" fix of a super magnet is now permanent and works very well. I really can't believe that LR didn't fit this as standard, presumably just to save a couple of quid. Whilst I had the Araldite out I also fixed the passenger door rubber strip where it meets the top of the door. Hey-ho, I never had such "fun" whilst owning Subarus & Fords. Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
11th Apr 2014 8:09pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
I fitted my glove box yesterday -but it took a lot of work to get it to fit the way I was happy with it.
Most pictures I've seen show the dash top sitting awkwardly and I wanted to get a fit that was more like it was before the mod. Click image to enlarge Click image to enlarge Details here: http://defender90xs.blogspot.co.uk/2014/05...ation.html http://defender90xs.blogspot.co.uk/ |
3rd May 2014 1:37pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
I've got the same problem with the lid not shutting properly What size are the original bolts? What do i need to buy in order to get it to close flush? |
8th May 2014 8:21pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1916 |
+1 for mobile storage systems, great easy to install piece of kit
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
8th May 2014 8:26pm |
Its a great bit of kit but i wish it was supplied with black fixings and two new flush bolts to replace the originals and allow the lid to close flush with the dash
Other than the fixings the quality is great. |
8th May 2014 8:28pm |
Jim,
Even with flush bolts it doesn't shut flush due to the thickness of the hinge. Flush bolts help as does the thin super magnet I used. Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
8th May 2014 8:31pm |
mark_d i really want to get the same result as you - looks superb
What fixings are those on the dash? Mine just doesn't sit right Click image to enlarge |
8th May 2014 8:33pm |
Hi Chris - i'm hoping i can get it a bit lower tho. Failing that i'll have to use some foam sealing tape - bit naff though
8th May 2014 8:34pm |
Chris - do you remember what size the original bolts were?
8th May 2014 8:40pm |
the britpart one fits much lower than that one in the pic , and looks the same design as the nak one
and if you fit it just right they sort of clip over the bottom edge |
8th May 2014 8:47pm |
Well i'm kind of stuck with the Mobile Storage one now. I'm hoping a change of fixings is all it needs.
8th May 2014 8:54pm |
Jim, no I just used some recessed head screws from my "they'll come in useful one day" drawer. They chewed their way into the plastic thing that secured the original self tappers. Unfortunately I'm a brute force & ignorance type of engineer, plenty of the former, not too much of the latter. Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
8th May 2014 11:00pm |
