Home > Puma (Tdci) > swivel housing grease |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I tried our local forum but have had no replies yet.
I cannot get an equivalent to Texaco Molytex EP00 as per the manual in our country. Tried Castrol/Caltex/Mobil here with no luck. Do you guys have this product locally or do you have other equivalents similar? I assume the TD5 must have had a similar grease Thanks Last edited by CapeLandy on 25th May 2010 11:48am. Edited 1 time in total |
25th May 2010 10:58am |
Thanks. never thought of trying the dealer route. I guess that it is such a small quantity they can't possibly charge the earth for it.
I just want to open my filler plug and make sure there is some still in there as opposed to in the diff through the seals. Last oil change revealed quite a bit of grease in the diff oil. |
25th May 2010 11:47am |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
As above, the one-shot greasers are about £5 each. Each one contains enough to completely repack the swivel housing. Always got a couple on the shelf - just haven't had the need to use them myself yet (although my old neighbour kept nicking them hence my "stock control")
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
25th May 2010 1:47pm |
