Home > Puma (Tdci) > swivel housing grease
CapeLandy
South Africa
I tried our local forum but have had no replies yet.
I cannot get an equivalent to Texaco Molytex EP00 as per the manual in our country.
Tried Castrol/Caltex/Mobil here with no luck.
Do you guys have this product locally or do you have other equivalents similar?
I assume the TD5 must have had a similar grease
Thanks
Post #32909 25th May 2010 10:58am
MK
it is the one-shot STC3435 Puma 110" SW
Post #32912 25th May 2010 11:36am
CapeLandy
South Africa
Thanks. never thought of trying the dealer route. I guess that it is such a small quantity they can't possibly charge the earth for it.
I just want to open my filler plug and make sure there is some still in there as opposed to in the diff through the seals. Last oil change revealed quite a bit of grease in the diff oil.
Post #32913 25th May 2010 11:47am
NoDo$h
As above, the one-shot greasers are about £5 each. Each one contains enough to completely repack the swivel housing. Always got a couple on the shelf - just haven't had the need to use them myself yet (although my old neighbour kept nicking them hence my "stock control")
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #32926 25th May 2010 1:47pm
