Home > Puma (Tdci) > Split pins for Puma brakes
ZeDefender
Hi all
I know this has been asked before but the answer doesn't help me...
I need some split pins for when I change the disc pads on the 110 (2.4) - please can anyone tell me what size they are? I need to order them as nowhere around here has them just knocking around.
Even better, can someone tell me where to order them from (UK is fine)?
Matt Tell someone you love them today because life is short.
Post #327971 3rd May 2014 8:35am
munch90
if your talking about the very small ones in the end of the main pins
it may be easier to buy a brake fitting kit which has 2x main pins 2x springs 2x split pins or whatever you need for your defender
you would need to get the right set for your defender
the kits are normally only a few quid ( on the bay �3.50 with post (uk) I would guess a lot more from land rover
and handy in case you lose something when fitting
Post #327972 3rd May 2014 8:45am
jimbob7
Usually Br*tpart on bayE but I fitted new pins last year and no problems(yet),even oem corrode. Pov.spec,ftw. 2006, 110,TD5.
Post #327978 3rd May 2014 9:10am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
STC8575
Post #327982 3rd May 2014 9:58am
ZeDefender
Cheers - a lot of the STC8575 kits have fancy "B" clips instead of split pins, e.g.
http://www.lrdirect.com/STC8575-Pad-Retent...tAodMS8A0g
I checked and my MY2011 has split pins.
Do you reckon they're all as good as each other? Tell someone you love them today because life is short.
Post #328005 3rd May 2014 12:45pm
jimbob7
I'd say yes. Pov.spec,ftw. 2006, 110,TD5.
Post #328006 3rd May 2014 12:53pm
ZeDefender
Okay - think I finally managed to find the kits I need in Germany from the same place and not costing a fortune Rolling Eyes
The part numbers STC8574 and STC8575 are listed for loads of vehicles so I just hope they are all identical.
Thanks to all Thumbs Up Tell someone you love them today because life is short.
Post #328011 3rd May 2014 1:13pm
