Home > Puma (Tdci) > Split pins for Puma brakes |
Hi all
I know this has been asked before but the answer doesn't help me... I need some split pins for when I change the disc pads on the 110 (2.4) - please can anyone tell me what size they are? I need to order them as nowhere around here has them just knocking around. Even better, can someone tell me where to order them from (UK is fine)? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd May 2014 8:35am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Usually Br*tpart on bayE but I fitted new pins last year and no problems(yet),even oem corrode. Pov.spec,ftw. 2006, 110,TD5.
3rd May 2014 9:10am |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
STC8575
3rd May 2014 9:58am |
Cheers - a lot of the STC8575 kits have fancy "B" clips instead of split pins, e.g.
http://www.lrdirect.com/STC8575-Pad-Retent...tAodMS8A0g I checked and my MY2011 has split pins. Do you reckon they're all as good as each other? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd May 2014 12:45pm |
I'd say yes. Pov.spec,ftw. 2006, 110,TD5.
3rd May 2014 12:53pm |
Okay - think I finally managed to find the kits I need in Germany from the same place and not costing a fortune
The part numbers STC8574 and STC8575 are listed for loads of vehicles so I just hope they are all identical. Thanks to all Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd May 2014 1:13pm |
