![]() | Home > Puma (Tdci) > A bar genuine, light fitment option? |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
What are my options to install the lights on the genuine a -bar?
How do light force look? What is a good size I don't want something tacky..I like something that had good power and looks oem. 2016 Defender 90 Adventure Edition |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Imo, lighforce 170's are the boyo, 240's are too big IMO and the lighting from the 170 is more than enough for me.
170's also bolt directly onto the genuine 'abar' ![]() Click image to enlarge |
Any more pic, I'm looking to add black transparent cover on them 2016 Defender 90 Adventure Edition
Suggest you contact by PM forum member kitoper. He has a pair of the recently launched new Hella LED high beam lamps just installed on his Hunter edition. Best looks and best quality light I have ever seen. They are a nice match with his Nolden too. ![]() I will see kitoper tomorrow in the office, and will mention to him to look for your PM if you would want to do that. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Made my own brackets to 'pick up' the holes on the a bar securing brackets.
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I don't want a complicated install nor do I want something being too big, I like the oem look but open to non oem stuff. I like the idea of Hella's as I have Nolden headlamps on the way (chrome finish)
The LED Luminater vs Rallye model, Which looks better ? ![]() ![]() |
I like how they fit the bumper nicely, not big or small as oem lights
![]() Click image to enlarge 2016 Defender 90 Adventure Edition |
I like the look of these, any one know where I can get them ? 2016 Defender 90 Adventure Edition |
ZZPLUG01 Connector Kit for Defender
YUG000540LNF So I ordered the Aux 2 switch and the necessary connector ![]() Also Soft A bar nudge bumper winch model 2016 Defender 90 Adventure Edition |
So I was researching parts, I think I will stick with Light Force 170 meets my budget.
for those who installed it do I need stuff or brackets to install, the LR A Nudge bar will come with the required brackets ? The other items I mentioned in previous responses are okay ? Switch for the interior button and the connector ? 2016 Defender 90 Adventure Edition |
As a matter of fact, I was talking about none of those two. But an entirely new Hella lamp. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Okay, any picture ? I have pm'd the person you referred me to. 2016 Defender 90 Adventure Edition
Surely he will respond to you. You never actually own a Defender. You merely look after it for the next generation.
^^ Brendan, any good suggestions for that? I have seen someone installed something from you which seems connected to an engine bolt, but wonder how accurate that is.
I would prefer a temperature gauge and a sensor which gives the exact water temperature as is the case with most other cars. Something like an extra 70mm VDO water temp gauge which be built into the side of center console with a reliable extra water temp sensor under the hood.... Even better would be if the standard water temp gauge in the Puma dash could be reprogrammed in order to show the real temp, and not be stuck in the middle until it would eventually flip up all the way into red.... when it probably is too late. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
