Home > Puma (Tdci) > A bar genuine, light fitment option?
SkyFallSilver
Kuwait
What are my options to install the lights on the genuine a -bar?
How do light force look? What is a good size I don't want something tacky..I like something that had good power and looks oem. 2016 Defender 90 Adventure Edition
Post #327297 30th Apr 2014 6:20pm
Likeomg
Imo, lighforce 170's are the boyo, 240's are too big IMO and the lighting from the 170 is more than enough for me.
170's also bolt directly onto the genuine 'abar'
Post #327300 30th Apr 2014 6:28pm
SkyFallSilver
Kuwait
Any more pic, I'm looking to add black transparent cover on them 2016 Defender 90 Adventure Edition
Post #327301 30th Apr 2014 6:31pm
ericvv
Re: A bar genuine, light fitment option?
Suggest you contact by PM forum member kitoper. He has a pair of the recently launched new Hella LED high beam lamps just installed on his Hunter edition. Best looks and best quality light I have ever seen. They are a nice match with his Nolden too.Thumbs Up
I will see kitoper tomorrow in the office, and will mention to him to look for your PM if you would want to do that.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #327313 30th Apr 2014 6:50pm
K9F
Made my own brackets to 'pick up' the holes on the a bar securing brackets.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #327318 30th Apr 2014 6:53pm
SkyFallSilver
Kuwait
I don't want a complicated install nor do I want something being too big, I like the oem look but open to non oem stuff. I like the idea of Hella's as I have Nolden headlamps on the way (chrome finish)
The LED Luminater vs Rallye model,
Which looks better ?
Post #327416 30th Apr 2014 10:04pm
SkyFallSilver
Kuwait
I like how they fit the bumper nicely, not big or small as oem lights
Post #327433 30th Apr 2014 11:43pm
SkyFallSilver
Kuwait
I like the look of these, any one know where I can get them ? 2016 Defender 90 Adventure Edition
Post #327434 1st May 2014 12:00am
SkyFallSilver
Kuwait
ZZPLUG01 Connector Kit for Defender
YUG000540LNF
So I ordered the Aux 2 switch and the necessary connector Smile
Also Soft A bar nudge bumper winch model 2016 Defender 90 Adventure Edition
Post #327438 1st May 2014 3:35am
SkyFallSilver
Kuwait
So I was researching parts, I think I will stick with Light Force 170 meets my budget.
for those who installed it do I need stuff or brackets to install, the LR A Nudge bar will come with the required brackets ?
The other items I mentioned in previous responses are okay ?
Switch for the interior button and the connector ? 2016 Defender 90 Adventure Edition
Post #327440 1st May 2014 4:52am
ericvv
As a matter of fact, I was talking about none of those two. But an entirely new Hella lamp. You never actually own a Defender. You merely look after it for the next generation.
Post #327441 1st May 2014 5:20am
SkyFallSilver
Kuwait
Okay, any picture ? I have pm'd the person you referred me to. 2016 Defender 90 Adventure Edition
Post #327442 1st May 2014 5:33am
ericvv
Post #327448 1st May 2014 6:30am
leeds
Kuwait = high temperature! So lots of cooling needed.
Winch and large lights in front of radiator will hinder aif flow through radiator.
Will it be worthwhile to consider an engine coolant alarm??
Brendan
Post #327464 1st May 2014 8:00am
ericvv
^^ Brendan, any good suggestions for that? I have seen someone installed something from you which seems connected to an engine bolt, but wonder how accurate that is.
I would prefer a temperature gauge and a sensor which gives the exact water temperature as is the case with most other cars. Something like an extra 70mm VDO water temp gauge which be built into the side of center console with a reliable extra water temp sensor under the hood....
Even better would be if the standard water temp gauge in the Puma dash could be reprogrammed in order to show the real temp, and not be stuck in the middle until it would eventually flip up all the way into red.... when it probably is too late.
Post #327468 1st May 2014 8:39am
