Home > Puma (Tdci) > Anyone have these installed ?
SkyFallSilver
Kuwait
I like the idea of it written in arabic, however is this like a gate you need to open in order to reach the filler cap or has a cut in the middle to put it in the surface of the fuel filler cap area ?
 2016 Defender 90 Adventure Edition
Post #327127 29th Apr 2014 11:01pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
this is a piece of rubber...you bend it a little to fix it and remove it the same way when you need to fill the tank...press your nail between this and the body and remove it...very simple! and efective when you drive on mud and water! keeps the area clean! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #327128 29th Apr 2014 11:21pm
SkyFallSilver
Kuwait
No point in having it for my kind of use, mostly desert offroading. 2016 Defender 90 Adventure Edition
Post #327133 30th Apr 2014 2:32am
LR90XS2011
they are useful to keep dust/sand as well as mud out DEFENDER 90 TDCI XS,
Post #327137 30th Apr 2014 5:16am
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
I bought one 4 years ago and it's like new. Very high plastic quality.
It help to reduce the dust to attach to the area around the filler cap.
Post #327138 30th Apr 2014 5:17am
Naks
I also have one, and it helps to keep the gravel from clogging around the cap Thumbs Up --
Post #327153 30th Apr 2014 6:48am
leeds
Defendoors are made by an American called Mark in the Czech Republic by a vacuum forming process. It is a minor offshoot of their main business supplying parts go the German car business.
Have used them for years and they certainly keep the majority of crap out from the fuel filler area. Thumbs Up
Useful in dry dusty conditions as well as that drop or two of diesel spilt and some sand can become a sticky mess.
Brendan
Post #327156 30th Apr 2014 6:57am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Yip....I second that.
Also have one and keeps dust out and the filler nice and clean.
Ps....I also bought it because of the last sentence on it...it is written in Afrikaans!
Post #327162 30th Apr 2014 7:24am
AlanH
Australia
I've got one and it keeps a lot of the red Pilbara dust out of the filler area. I've also burnt my initials ATH in it as I saw a weasely looking bloke looking lustfully at it. Very Happy
AlanH.
Post #327174 30th Apr 2014 8:27am
smb
They are well worth the money especially if you have tyres that through mud/dust up the back from the rear wheels. Only problem is that mine keep getting nicked. Obviously proves that not all Defender owners are trustworthy Whistle
Get a couple(they're not expensive) and as AlanH mentions put your initials on. Or better still secure it with a wandering lead similar to the secure fuel filler caps.
Post #327178 30th Apr 2014 8:37am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have one also, helps stop the lock freezing in the winter. I have it secured with a bit of wire so I can't leave it at a filling station or loose it if it fell off.
Post #327499 1st May 2014 10:25am
Merlin
My first one fell off, but they kindly supplied a replacement. Now
I have it secured with a strap. I think this should be standard.
Merlin
Post #327524 1st May 2014 12:57pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
I have used one since I picked up the Defender.
Fits snugly and keeps dirt out, for very little £. 1970 Series 2A 88"
Post #327526 1st May 2014 1:22pm
trick is keeping hold of them, they have been known to "fall off"
Post #327551 1st May 2014 3:39pm
