![]() | Home > Puma (Tdci) > Anyone have these installed ? |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
I like the idea of it written in arabic, however is this like a gate you need to open in order to reach the filler cap or has a cut in the middle to put it in the surface of the fuel filler cap area ?
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
this is a piece of rubber...you bend it a little to fix it and remove it the same way when you need to fill the tank...press your nail between this and the body and remove it...very simple! and efective when you drive on mud and water! keeps the area clean! Regards
Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
No point in having it for my kind of use, mostly desert offroading. 2016 Defender 90 Adventure Edition
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
they are useful to keep dust/sand as well as mud out DEFENDER 90 TDCI XS,
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I also have one, and it helps to keep the gravel from clogging around the cap
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Defendoors are made by an American called Mark in the Czech Republic by a vacuum forming process. It is a minor offshoot of their main business supplying parts go the German car business.
Have used them for years and they certainly keep the majority of crap out from the fuel filler area. ![]() Useful in dry dusty conditions as well as that drop or two of diesel spilt and some sand can become a sticky mess. Brendan |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Yip....I second that. Also have one and keeps dust out and the filler nice and clean. Ps....I also bought it because of the last sentence on it...it is written in Afrikaans! |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I've got one and it keeps a lot of the red Pilbara dust out of the filler area. I've also burnt my initials ATH in it as I saw a weasely looking bloke looking lustfully at it.
![]() AlanH. |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
They are well worth the money especially if you have tyres that through mud/dust up the back from the rear wheels. Only problem is that mine keep getting nicked. Obviously proves that not all Defender owners are trustworthy
![]() Get a couple(they're not expensive) and as AlanH mentions put your initials on. Or better still secure it with a wandering lead similar to the secure fuel filler caps. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
I have one also, helps stop the lock freezing in the winter. I have it secured with a bit of wire so I can't leave it at a filling station or loose it if it fell off.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
My first one fell off, but they kindly supplied a replacement. Now
I have it secured with a strap. I think this should be standard. Merlin |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
I have used one since I picked up the Defender.
![]() Click image to enlarge Fits snugly and keeps dirt out, for very little �. 1970 Series 2A 88" |
trick is keeping hold of them, they have been known to "fall off"
