![]() | Home > Puma (Tdci) > Screaming Turbo when Hot |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5855 ![]() ![]() |
Thanks
![]() What's "special nuts" about ![]() Andy |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
There are not ordinary steel nuts,you can ask for nuts for trubo(high temperature) applications.
For example, http://midnighttouge.blogspot.gr/2013/05/t...-your.html |
Carrotbay is right,i forgot to mention that i(the puma i mean
![]() Apologies if i mislead you ![]() |
Great. Thanks all will have a go tomorrow.
![]() Andy |
Zouritte Member Since: 29 Jan 2014 Location: Ain Posts: 69 ![]() ![]() ![]() |
Hi guys,
Had the same problem on my def after fitting a decat, a big whistling sound as soon as the engine gets hot (temp needle in the middle range). After investigation and Defender2 helpful posts have been able to see the problem. the previous owner or LR didn't tighten one of the manifold to turbo nuts at all (few millimetres out). After fitting the decat the wheight of it or just the manipulations around the turbo made the gasket move or split (see picture below) "ergo" the whistling. So idiot as i am i tried to tighten it, but with the time and temperature the bolt got old and fragile so i broke it....I had to remove the whole turbo, replace the nuts, bolts a few gaskets and fitted the Nakatanenga gasket. Now it's all gone, the decat is on and no more whistling. ![]() Click image to enlarge the original gasket in bad shape Thanks for your help with the forum.. Cheers Tim |
Timely resurrection of this post, as I'm doing mine again at the moment.
Bloody crappy Ford quality, hoping the decat will help with this, so not have to repeat again. . Andy |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Hi
After changing the gasket a couple of times (including having to replace a Nak one) I used some 'turbo paste' the last time with the gasket and haven't had a leak since. I'm assuming I have a small warp that this deals with. http://www.demon-tweeks.co.uk/motorsport/w...eliminator Worked for me. ![]() |
well...
I finally gave up, removed the turbo and ground both the manifold and turbo faces flat. Since I have had two Nak gaskets and they both deformed outwards along the thinnest edge, I also made a heavy-heavy-duty one out of 3mm copperplate and annealed it. The design is basically the same as the Nak/original but curves outwards by about 10mm along the thinnest edge and 5mm along the others (like a bulging triangle). The gasket also protrudes inside the hole by a couple of mm on the thinnest edge. The colder copper outside the joint helps the copper inside not to distort. It's been okay with a big-ass turbo for a few months now (but I will never hold my breath) ![]() p.s. and I have fitted a temperature gauge in the turbo and don't drive like a loony any more ![]() But shout it at them in German because life is also terrifying and confusing... |
That makes 3 of us doing the same job again ![]() |
Matt As i am still waiting for those manifold gaskets to arrive (almost a month ![]() ![]() ![]() ![]() |
