Home > Puma (Tdci) > Flat battery protection?
ZeDefender
"A friend of mine" accidentally left the ignition on overnight whilst charging his iPhone and laptop - unfortunately the blower motor was also on Thud so when he tried to start up there was absolutely nothing. Not a peep. Fortunately my... err... "friend" has 2 batteries (Odysseys) so the vehicle started on the second one.
So my question is: are the Puma electronics sensible enough to cut the power (e.g. to the blower) when the battery voltage falls below a certain level or is the battery just drained until coma?
Matt Tell someone you love them today because life is short.
Post #325985 25th Apr 2014 1:01pm
munch90
don't think there is a protection device , but maybe relays would disconnect (not enough voltage to work coil in relay ) when voltage drops
maybe there is in side control modules like engine ecu , alarm ecu
Post #325987 25th Apr 2014 1:13pm
smb
There are devices you can install that will disconnect all power if it senses low voltage. This is to enable a single start to get you out of trouble.
I have the same with two Odysseys and have installed the IBS DBS Battery Monitor system with the added Booster Relay AND LBP180 Battery Protection. Have tried running the main battery flat and it all works perfectly by taking the starting power from the second battery.
See here(if the link works):
http://ibs-tech.ch/en/products/dual-batter...uproc.html
I think you can buy this system from TBR if in the UK.
Post #325991 25th Apr 2014 1:25pm
K9F
At a quick glance something like this perhaps. But isn't that one of the functions of the ignition? You have to weigh up the odds of actually needing one I suppose?
http://uk.rs-online.com/web/p/monitoring-relays/3216860/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #325996 25th Apr 2014 2:26pm
Cupboard
Has your, err, friend, considered charging his phone and laptop from his second (non starter) battery to avoid this from happening?
Post #325999 25th Apr 2014 2:39pm
Matt,
your "friend" is really stupid, maybe tell him/her to put the defender in tha garage, lock the garage, and give the keys to his other half Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #326028 25th Apr 2014 5:33pm
PaulMc
Have a look at -
http://www.noflatbatteries.com/
. Paul.
Post #326036 25th Apr 2014 6:14pm
Matt are you sure it wasn't you. Whistle
Post #326057 25th Apr 2014 7:41pm
ZeDefender
Embarassed Embarassed Embarassed
Paul, that looks great. Idiot -proof (just what I need) Whistle
Thanks all. I've been using the vehicle all day with no problems - started fine after only 1/2 hour charging on the move, so I guess that means I... er I mean "my friend" hasn't completely crippled the main battery Wink Tell someone you love them today because life is short.
Post #326095 25th Apr 2014 9:02pm
Just nearly screwed it up. Whistle Rolling with laughter
Post #326101 25th Apr 2014 9:13pm
