Page 667 of 1377 <123 ... 666667668 ... 137513761377>
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Decided as it was going to be wet, I'd take SWMBO out for Sunday lunch, so we went to Marborough. Nice easy drive along the M4 and came back the scenic route via Hungerford. _______________________________
Puma Defender 90
Post #324993 20th Apr 2014 10:15pm
Landy-Novice
derbywill wrote:
that S1 is stunning!!! Thumbs Up Bow down
Post #324995 20th Apr 2014 10:27pm
ericvv
Post #325008 21st Apr 2014 5:23am
LR90XS2011
x3 Thumbs Up love series 1s DEFENDER 90 TDCI XS,
Post #325010 21st Apr 2014 6:11am
Pickles
derbywill wrote:
Not a defender, but fitted a new exhaust manifold to the series 1 and washed the cobwebs of it. Gave her a 5mile run to make sure everything is ok.
Love those classic Lucas lights AND covers!
Cheers, Pickles.
Post #325013 21st Apr 2014 6:40am
Dirtpod
Australia 2011 Defender 110 Puma 2.4 SW Java Black
Post #325056 21st Apr 2014 12:05pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
Cleaned cleaned and cleaned
Post #325066 21st Apr 2014 1:02pm
dwilliams851
Chile 2010 Defender 110 Puma 2.4 SW Galway Green
You forgot to clean the drive (can of redbull) ---------------------------------------------
Past LR's
Series 2a, Range Rover Vogue, Disco 3, Disco 2, Disco 1
Defender 110 Puma
http://www.flickr.com/photos/bambi851/
Post #325069 21st Apr 2014 1:09pm
mk1collector
Cleaned out the dustbin that was the inside Rolling Eyes
Post #325079 21st Apr 2014 1:50pm
green 110 got a good clean, sorted out the paint for the merlin Thumbs Up
Post #325099 21st Apr 2014 3:17pm
ericvv
Thoroughly vacuumed the SVX today. Got rid of all the pollen that are being accumulated this time of the year. The outside is slowly turning yellow instead of black right now with all the rapeseed fields in bloom here. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #325100 21st Apr 2014 3:23pm
Nobby
Forgot to put one of the Bee syrup feeder lids on correctly so had a nice sweet sugary carpet in the back. Too lasy to put the tray in the back so accidents like this don't happen. As I spent the afternoon working on the 90 it was a magnet for Bees all afternoon until the rain came. Used the steam cleaner and no more syrup or Bees. _______________________________
Puma Defender 90
Post #325146 21st Apr 2014 6:12pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Voltage tested the towing electrics (12N). All looked fine. Continuity tested the trailer electrics. All looked fine, bar a couple that wouldn't actually wire up to anything on the trailer (I *think*).
Sat and wondered why the blooming lights don't actually reliably come on when I plug the two together. Suspect it's because both connectors show signs of corrosion, so looks like I'll be off to Halfords for some contact cleaner (and some sort of conductive gel?). 2009 110 XS Station Wagon
Post #325167 21st Apr 2014 7:40pm
Most likely the trailer plug if it's been sitting about for a while.
Change it for a new one, they are only cheap and go from there. That's what I'd recommend anyway.
Thumbs Up
Post #325168 21st Apr 2014 7:46pm
timbar
That might save me a couple of hours getting covered in grim chemicals and fiddling with rolled up 220-grit sandpaper. Ta Smile 2009 110 XS Station Wagon
Post #325169 21st Apr 2014 7:47pm
