![]() | Home > Puma (Tdci) > Help somebody has replaced my Puma with a poorly 2.25 diesel |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 ![]() ![]() |
Does anybody else have the following symptoms (07MY puma 2.4L, 60000kms):
Starting in the morning from cold (ie negative temperatures) I get a cloud of blue smoke and an engine that sounds like a poorly 2.25 SIII diesel after 400,000 miles. After 10 seconds the blue smoke stops, but the engine still rattles like a bag of nails. Now, until the engine is hot (i mean the temp guage needle horizontal - normal running temp) I can't take the engine above 2000rpm without it sounding like a machine gun, and the engine trying to run away (accelerate out of control), certainly no turbo whine and seems to be low on power. Strangely, pressing the clutch stops this, and the symptoms go away when the engine is up to running temperature. However, it still appears to make more noise than before, although the power is there, and it seems to run OK. However the engine (Mis-)management warning light doesn't come on. This has been a gradual change over the last 20000kms, but is starting to get annoying. my local dealer came up with - no fault codes = no problem, which I am sure is a well known response ![]() As I am starting to get a bit worried, any ideas would be appreciated, so I can point my dealer in the right direction? For all those that read these posts and think.... with all these problems I will never by a defender, I would like to add that this is the first problem I have had with it, and would replace it with another without hesitation..... the whole family loves the beast (or Snotty as she is called) |
could be the fuel pressure relief vave 2.4 90 XS
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
larofly Member Since: 03 Jan 2008 Location: In my Def Posts: 2 ![]() ![]() ![]() |
This is what you after???
Title: 2.4 Puma Engine Knock Noise. Type: LD - Defender - All Years - Special Service Messages - Engine Name / Part No: SSM38792 Info Type: Service Bulletins Version No: 1 Date Uploaded: 21 Jul 2008 Models: LD - Defender Title: 2.4 Puma Engine Knock Noise. Last Modified: 21-JUL-2008 09:44 Category: Engine Symptom: 497000 Engine Noise Content Issue: Heavy audible knocking heard on start up. Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur. Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used. This condition will not occur on vehicles post assured Vin# 9A767162. Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
im maybe developing this kind of sound during morning start ups. its a strange sound just like a metal to metal sound. i just clock 20T kms already. could this be the start?my plate is A751817
Yes back to your dealer and tell him about your worry`s. And after Thad tell him about this.
![]() Special Service Messages - Engine Name / Part No: SSM38792 |
Check that there is no water in your fuel filter
carlostama Member Since: 28 Oct 2009 Location: Panama City Posts: 6 ![]() ![]() |
Hi everibody, i had the same problem 2 months ago. It was solve before big figth with the dealers.
The solutions was to change the EGR valvle N° part: LR006650. The def is now like a new one. Sorry for my english and nice to meet all of you. |
Hi and welcome nice truck you have
I have a good running 1984 2.5 l n.a. diesel lying around, I don't mind swapping it for your poorly running 2.25
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
maggieforrest Member Since: 22 Apr 2010 Location: Lancashire Posts: 8 ![]() ![]() |
Just been complaining about a very similar problem a few weeks ago here with mine. Just got it back after a month diagnosing at a local diesel specialist. Problem found eventually to be injector number 3, however, the other 3 will probably need changing before the year is out. An ouch at £208 per injector, plus diagnosing, ECU remapping etc. But at least I have a car back. Was told 'it could be dodgy fuel causing the injectors to wear somewhat quicker' My car is now at 175000 miles. Very low. |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi,
I've had a similar problem on starting once on my way from Spain to UK. The fault was water in the fuel. I stopped a couple of Kms to fill the tank up and the fuel must have been contaminated with water. Cure - I refilled the tank at the earliest possible opportunity in another petrol station and darined the fuel filter. Voila - No Problems since. PS: Those bloody rascals of Spanish petrol pumps trying to make extra money by adding water to Diesel!! joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
