Home > Puma (Tdci) > Help somebody has replaced my Puma with a poorly 2.25 diesel
67_6Cyl
France
Does anybody else have the following symptoms (07MY puma 2.4L, 60000kms):
Starting in the morning from cold (ie negative temperatures) I get a cloud of blue smoke and an engine that sounds like a poorly 2.25 SIII diesel after 400,000 miles. After 10 seconds the blue smoke stops, but the engine still rattles like a bag of nails.
Now, until the engine is hot (i mean the temp guage needle horizontal - normal running temp) I can't take the engine above 2000rpm without it sounding like a machine gun, and the engine trying to run away (accelerate out of control), certainly no turbo whine and seems to be low on power. Strangely, pressing the clutch stops this, and the symptoms go away when the engine is up to running temperature. However, it still appears to make more noise than before, although the power is there, and it seems to run OK. However the engine (Mis-)management warning light doesn't come on.
This has been a gradual change over the last 20000kms, but is starting to get annoying.
my local dealer came up with - no fault codes = no problem, which I am sure is a well known response Evil or Very Mad
As I am starting to get a bit worried, any ideas would be appreciated, so I can point my dealer in the right direction?
For all those that read these posts and think.... with all these problems I will never by a defender, I would like to add that this is the first problem I have had with it, and would replace it with another without hesitation..... the whole family loves the beast (or Snotty as she is called)
Post #24004 10th Feb 2010 4:37pm
Grockle
could be the fuel pressure relief vave 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #24005 10th Feb 2010 4:56pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Get back to the dealer and start stamping your feet! Being a 2007 its going to be out of warranty at some point this year.... you dont want them dragging their feet so it goes out of warranty and then ends up costing YOU to get it fixed.
Just my opinion Wink Mark
2011 110 XS DC
Stornoway Grey
Post #24015 10th Feb 2010 7:58pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Wasn't there a problem with the early 2007 engines and the oil circulation or something at startup. Get the dealer to go through the LR service bulletins. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #24017 10th Feb 2010 8:08pm
larofly
Netherlands 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Re: Help somebody has replaced my Puma with a poorly 2.25 di
This is what you after???
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
Post #24161 12th Feb 2010 9:39pm
totoD110
im maybe developing this kind of sound during morning start ups. its a strange sound just like a metal to metal sound. i just clock 20T kms already. could this be the start?my plate is A751817
Post #25585 2nd Mar 2010 9:36am
larofly
Yes back to your dealer and tell him about your worry`s. And after Thad tell him about this. Rolling Eyes
Post #25587 2nd Mar 2010 10:21am
AndrewS
Check that there is no water in your fuel filter Thumbs Up
Post #25588 2nd Mar 2010 10:31am
carlostama
Panama
Hi everibody, i had the same problem 2 months ago. It was solve before big figth with the dealers.
The solutions was to change the EGR valvle N° part: LR006650.
The def is now like a new one.
Sorry for my english and nice to meet all of you.
Post #25621 2nd Mar 2010 8:27pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Hi and welcome nice truck you have Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #25623 2nd Mar 2010 8:41pm
roel
I have a good running 1984 2.5 l n.a. diesel lying around, I don't mind swapping it for your poorly running 2.25 Rolling with laughter Roel
2003 90 Td5 (2009-now)
Post #25666 3rd Mar 2010 7:34am
maggieforrest
2007 Defender 110 Puma 2.4 XS DCPU Santorini Black
Just been complaining about a very similar problem a few weeks ago here with mine. Just got it back after a month diagnosing at a local diesel specialist. Problem found eventually to be injector number 3, however, the other 3 will probably need changing before the year is out. An ouch at £208 per injector, plus diagnosing, ECU remapping etc. But at least I have a car back.
Was told 'it could be dodgy fuel causing the injectors to wear somewhat quicker' My car is now at 175000 miles. Very low.
Post #32467 18th May 2010 4:07pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Rough running 2.4
Hi,
I've had a similar problem on starting once on my way from Spain to UK. The fault was water in the fuel. I stopped a couple of Kms to fill the tank up and the fuel must have been contaminated with water.
Cure - I refilled the tank at the earliest possible opportunity in another petrol station and darined the fuel filter.
Voila - No Problems since.
PS: Those bloody rascals of Spanish petrol pumps trying to make extra money by adding water to Diesel!!
joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #32469 18th May 2010 4:39pm
