![]() | Home > Maintenance & Modifications > Best brake pads and discs |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1635 ![]() ![]() |
I like ones with some linings left in them
Most of the major brands last well with no issues. I'm currently running a set of ebc uprated pads n discs on a td5 Discs last well. Pads wear faster but better braking works for me Depends on what car and what you want. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
EBC pads for me, improved braking but fade is an issue if used very heavily.
Saying this I am running standard discs. |
fitted hundreds of sets of APEC , never had a problem or complaints
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Hmm well needs to stop my truck lol I was thinking ebc pads but not sure may change discs to the paddocks own ones ?
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
I run Paddocks own grooved/drilled discs and EBC pads ... no complaints whatsoever
-[Allan]- Member Since: 22 Mar 2014 Location: West Yorkshire Posts: 44 ![]() ![]() ![]() |
Brembo drilled / vented front and drilled / solid rear though you will have to import them from the USA and they aren't cheap! Fitted a set to one of my 50th's a few years back and they were excellent.
Genuine Land Rover pads unless you want to reduce brake dust staining then go for Greenstuff pads. |
OEM. Pov.spec,ftw. 2006, 110,TD5.
And when I mention brake fade earlier I only had that once and that was after and all day drive and on a very very long hill. Pollock hill.
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
These
![]() ![]() ![]() Im using standard discs with brembo pads on the rear. No problems with stopping. William |
Computer isn't working well tonight. William
Double post
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Has anyone used the DBA 4000 series discs?
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
OEM discs with Greenstuff pads work very well for me
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 ![]() |
Strange the love for EBC Greens.
I put them on one of my other cars and they are, without a doubt, the worst pads I've ever used. Soft, spongy, and not confidence inspiring. I'd go OEM, Ferodo, or Mintex (although the latter I've always found dusty). |
