Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 4 of 16 <123 45 ... 141516>
K9F
Yes I do! I think mass air flow through the engine is an important factor! The hole in the blank I believe is necessary to allow a calibrated leak across a Mass Airflow Sensor, thereby keeping your MIL light off. That said if you can increase mass airflow efficiency through the engine you should be able to reduce the EGR Valve blank hole size!
I am sure someone will be along to correct me if I am wrong! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32358 17th May 2010 7:59am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Just like to say that I am following this thread with great interest. I am especially interest in how the vehicles run with regard to MPG. This is not something I would consider doing usually as I like not to give the dealers the opportunity to say “ah but you have had this done ..bla...bla...bla”. However after the dealers downloaded an ecu update in December it runs like a bag of spanners (seams very noisy and rough engine note) and uses more fuel than it ever did (at least 2mpg worse).
So keep the reports coming and a great thread. Thumbs Up
Thanks
Boy
Post #32364 17th May 2010 9:01am
Grockle
Justin which download did the dealer do V2 or V4 ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #32365 17th May 2010 9:03am
The Boy
OK I am going to embarrass myself here.
I don’t know Embarassed
When I got it back I noticed right away that it had a rough engine note but did seem to have more guts. However when I tried to put BAS back in it would not go so I knew it had been done. Swivel seal went with in 1k so it had to go back. By then I had figured out it was doing about 2-3mpg worse (with or without tune). When I spoke to the service manager and asked what had been done to the ecu he just said “has it?” and “How do you know we had done anything” So I said because of the way it drives and how much fuel it uses. He said the wasn’t aware of the download but would get back to me but never did. Oh and I also get fault codes on there now but no mil light.
Is there a way of finding out which one was downloaded?
Boy
Post #32366 17th May 2010 9:20am
K9F
The Boy,
Is this......
The Boy wrote:
This is not something I would consider doing usually as I like not to give the dealers the opportunity to say “ah but you have had this done ..bla...bla...bla”.Boy
not a complete contradiction in terms with this?.....
The Boy wrote:
However when I tried to put BAS back in it would not go so I knew it had been done. Boy
You won't consider fitting a blank that can be reverted back to standard in a matter of 10 minutes or so but did have a BAS remap?
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
The Boy wrote:
Is there a way of finding out which one was downloaded? Boy
Short answer is 'No!' Only by asking them. If your vehicle is now running so badly go back and insist they reload the latest software in it's entirety.
I had a similar problem with my remap reload post an EGR Valve replacement and 'software upgrades/rewrite and am still waiting for Autologic to get round the added gremlins in Land Rover's latest software. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32368 17th May 2010 9:48am
The Boy
Yes but they don't know about the BAS (I hope) Mr. Green
Anyway my 110 is completely standard.
Apart from the BAS tune, oh and the auxiliary electrics, yes and the 8.5” wheels Rolling Eyes , and the tyres (but they go with the wheels. Oh and yes there is that HD bumper but that’s ok, I think? Does the roof rack count? Steering guard also but I need that. And the only reason I have that wheel carrier on is because the land rover one on the door is pants. I don’t think the Isotta steering wheel really matters. The security cubby box should have been fitted as standard anyway. Light guards goes without saying (front and back)
OK,OK so apart from those my 110 is completely standard.
Have I missed anything?
Post #32369 17th May 2010 10:04am
K9F
My point is that as with the BAS map you so deftly removed from your vehicle prior to going into the dealers, you can do exactly the same with the EGR Valve blank if you so wish. Using the notion of 'I don't want to give the dealers any excuse' is a little lame in the context of an EGR blank I think in this case.
Did bring a smile when you listed all the other extras. Nice one! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32370 17th May 2010 10:08am
The Boy
Yeah I do "lame" well Laughing
Really boils down to laziness, taking the tune off and then back on is easy and has no risk of me swearing and throwing spanners across the garage, or being ordered by the wife to “go next door and apologise to the neighbours for my language” who happen to be self righteous ramblers who have nothing better to do with their time than complain just about anything especially if it has something to do with two planet killers I have sat in the front drive(sorry I digress). Anyway if it is really that easy even for a complete spanner spastic like myself then I may well give it a go. Bit more motivation building by you lot and who knows I’ll be doing my own services next.
Reading back the above I think I may be in danger of getting old, “one foot in .... “ and all that.
Laughing
I am still looking forward to more updates though so please keep it up guys. Thumbs Up
Boy
Post #32374 17th May 2010 10:33am
Grockle
Boy
yes, just ask them which it was 2.4 90 XS
Post #32375 17th May 2010 10:33am
K9F
The Boy,
That's why I posted the instructions with photographs on the previous sheet, to ensure the process is laid out for those not so technically acute, too lazy, or with Victor Meldrew tendancies.
Fekete's giving it a go today and I asked him to let us know how he gets on!
A word of caution if you haven't got chequerplate watch your wingtops. I stood on the bumper with my knee on the wing for better access. Shortar5e5 may have to get a box or two out to stand on.
Neighbours.....Wait til they weed their borders and get a couple of handfulls of grass seed and throw it on their borders when finished.
Get a spade and find a few fresh molehills....Catch a mole or two and take them home....Wait til dark, take moles and a dustbin lid onto neighbours lawn. Place mole under dustbin lid on grass, wait for two to three minutes, only one way for mole to go....Downwards. They'll be cursing for weeks.
Dog Thumbs Up Dog
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32376 17th May 2010 10:48am
The Boy
Thank you Rolling with laughter (Tip hat smiley)
The old mole thing made me think of Jasper Carrot, "only one way to kill a mole........."
Sorry did I miss out checker plate on my list, oh yes more than you can shake a starting handle at!
I studied the photo’s and it does as you suggest look very easy even for a simpleton like me. As I have said the feedback is, relevant, informative and interesting which is why I am enjoying the thread so much (couscous that I don’t post a lot on here).
Boy
Post #32378 17th May 2010 11:00am
K9F
MPG
Filled up with fuel today....With the 18mm EGR valve plate fitted, same journey as ever, driving like a go-kart (Fekete can vouch for that) I managed an increase in economy of 2.7 mpg.
I now have the 16mm plate fitted and will continue to monitor fuel economy just in case it may not be a trend caused by the blanking plate.
Did surprise me though always fill up to the gunnels and managed 184 miles on this tank til it reached the halfway mark, never managed that before. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32390 17th May 2010 3:45pm
The Boy
Please let us know what the next fill up is. I'd give Phil Popham's right arm for another 2.7 miles per gallon Bow down Bow down Bow down
Post #32391 17th May 2010 3:57pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
It's finally fitted Rolling Eyes ...well to be honest it is easy... but you do get a little engine rash on your left wrist... you have to have a step to stand on for the job and lie all over the wings and engine...and if your like me do the job on your own cos if you have a mate there to help you, you will fall out Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32394 17th May 2010 4:19pm
K9F
Good news Karlos,
You need to treat the rash like a jellyfish sting....honest! Someone needs to pee on it. Get Mrs F to do it, if not pop down I will. My aims not too hot though.
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32396 17th May 2010 4:43pm
