![]() | Home > Puma (Tdci) > Brand New 110 XS arrived last night! |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 907 ![]() ![]() ![]() |
Yeap.........their nickname is Crapstones for a reason......
Jim |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
could be wrong but I'd have thought your SHOULD have a high level brake light - tell them to sort as its a h&s risk otherwise.
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 ![]() ![]() |
![]() I thought it was a legal requirement nowadays to have a high level brake light! |
The grab handle I was referring to is the big one on the dash infront of the passenger seat
leealanr Member Since: 18 Mar 2014 Location: Addis Ababa, Ethiopia Posts: 33 ![]() ![]() |
Ah yes. Am fitting a glove box from Mud when I get back home, am looking to se if I can have one above door entry. I think u lose this grab handle .
The one I saw didn't lose that grab handle with the glovebox
That would be good. Not seen one in the flesh yet, so thanks.
alan l. |
Steve W Member Since: 30 Mar 2014 Location: West Sussex Posts: 224 ![]() ![]() |
Hi, looking good, could I ask please is there anything I need to be mindful of when fitting carpets? I have a 2013 90XS and it's on my list of jobs to do soon along with having the rears tinted. I did see a posting on here saying that you are best buying the carpets from LandRover as these will be the best, is this true or would you look around............ Cheers. |
I got my carpets from Land Rover Interior Solutions (LRI) off the tinternet. I'm pleased with the quality. They were pre-cut to shape and fitted pretty well with a bit of minor tweaking. I used a heat/fire resistant glue (although a spray one came with it I didn't use). Then end result is excellent I think. It's difficult to fit simply for the reason that the glue is instant so you have only one chance to get it right. I put down sound deadening material first. But it's made the vehicle feel more solid than it did before. It's well worth doing and the dog is far happier which is the main thing.
Ok cheers for that I'll give it a go....glad you mentioned soundproofing I forgot about that ! Ha ha .......
My Volvo estate has massive sound deadining mTerial under the bonnet.
Has anyone done something similar with the Defender bonnet? what was the effect/cost/practicailty please. alan l. |
