Home > Puma (Tdci) > Trailer indicator flash |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Funny, I just posted similar including comments about the trailer light.....
Don't worry about it, it's normal for it to just flash the once. If you are actually towing it will flash constantly when you indicate. Although it's something you don't really notice. Not towing = single flash Towing = flashing with indicator constant. Not sure why exactly if you didn't notice it before? Are the trailer lights LED or incandescent? |
11th Apr 2014 10:51pm |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 |
Sorry I didn't make it clear - it was the rear indicator on the defender that I repaired. I haven't towed anything since ownership (6 months), I don't even own a trailer.
I'm quite an observant person so I'm 100% certain that before today it has never flashed before. Then today halfway through my journey down the M1 it started to flash on first indicate and it's been the same since! I'm going to borrow a light board tomorrow and check to see if everything works, if so I guess it's nothing to worry about! Just very strange how it started out of the blue... |
11th Apr 2014 11:16pm |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 136 |
Yep, quite normal mine does that. Flashes constantly with a trailer on.
12th Apr 2014 4:45am |
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 |
Definately normal for trailer indicator to flash once without trailer lights plugged in....if it wasn't doing it before, you've probably fixed the fault 1959 Series 2 Ragtop
1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
12th Apr 2014 5:34am |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
I agree with the comments above.
12th Apr 2014 7:00am |
yes that's normal
12th Apr 2014 7:39am |
Are you running standard lights and relay or LED?
12th Apr 2014 9:33am |
don't think the led relay flashes it once without trailer
12th Apr 2014 10:34am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
The RDX led relay does. You adjust it to do that? LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
12th Apr 2014 10:57am |
taken from site about the rdx relay
please read bottom bit Have you noticed when you indicate the trailer light may flash once even when you are not pulling a trailer, well most other normal cars do not put a trailer light on for one flash. Well ours puts the trailer light when you are actually pulling a trailer. When you are driving without the trailer and you indicate the little trailer light will not flash. |
12th Apr 2014 11:23am |
taken from site about the rdx relay please read bottom bit Have you noticed when you indicate the trailer light may flash once even when you are not pulling a trailer, well most other normal cars do not put a trailer light on for one flash. Well ours puts the trailer light when you are actually pulling a trailer. When you are driving without the trailer and you indicate the little trailer light will not flash. |
12th Apr 2014 11:24am |
Well that's Defenders for you? Mine does. 1 flash when indicating, without trailer attached. Trailer light flashing with indicators when trailer, which has normal bulbs, is attached.
I have the RDX light kit, except for the front wing side indicators. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
12th Apr 2014 4:19pm |
Same as the above posts's last sentence for me.
12th Apr 2014 4:36pm |
Tested with lightboard over the weekend and all worked a treat.
Just another Defender quirk I think |
14th Apr 2014 3:23pm |
