Home > Puma (Tdci) > Clutch or Clutch pedal problems? |
can be part of spring or something in clutch plate or pressure plate has broken and is floating around and getting wedged in pressure plate causing clutch not to release fully then moves and ok then gets caught up again . this problem will feel worst on 1st or r gears and feel better has you go up the gears
does it go in gear ok when stationary and engine off if it does its not in the box , you need to try this when you having the problem not when it seems ok not a uncommon problem on all cars you don't normally get any strange noises pedal will feel ok and fault can come and go until the bit wedges in somewhere and stays there |
7th Apr 2014 7:28am |
johnr Member Since: 31 Jul 2010 Location: Red Hill, Brisbane, Australia Posts: 2 |
Hey Much90,
You were spot on!! One of the springs from the clutch had somehow worked its way out and was jamming the clutch it scored the pressure plate and wreck the slave cylinder bush/bearing. So all that replaced and a new Master cylinder and slave cylinder/throw out for good measure and he's a happy beast again!!! Cheers, JohnR JohnR 07 Defender 110 86 M1026 HMMWV 85 Kawasaki KLR650 71 BSA A65 Lightning 71 MkII Mini Cooper S 60 Austin Healey MkI Sprite x 3 58 Goggomobile Dart Past Landies: Serries II, 2 x Serries III, 96 Rangie HSE, 2002 Def. |
11th Apr 2014 4:59am |
that's good , glad to help
11th Apr 2014 2:45pm |
