Home > Puma (Tdci) > Clutch or Clutch pedal problems?
johnr
Australia 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi I have a 2007 110 Puma TDCi and have had a great run with this car, very few problems with over 150,000kms on the clock.
BUT
I found myself hopping in the car last Thr and went to drive off and found it difficult to get into 1st gear. I spent the next 3 days double clutching, crunching all the gears and generally fighting with the gearbox and cursing!! I booked the car in to the service guys explaining the problem. He asked if there had been any fluid leak from the master cylinder and I said no. The joint consensus was gear box out and slave and clutch more than likely.
On the way home Sun night it got better???? Drove to the mechanics perfect no problems??? So we decided to keep an eye on it. Drove around a bit today and bingo same fault!!
How does a clutch get better??? Then fail again??? Any ideas would be greatly appreciated Very Happy
Cheers,
JohnR JohnR
07 Defender 110
86 M1026 HMMWV
85 Kawasaki KLR650
71 BSA A65 Lightning
71 MkII Mini Cooper S
60 Austin Healey MkI Sprite x 3
58 Goggomobile Dart
Past Landies: Serries II, 2 x Serries III, 96 Rangie HSE, 2002 Def.
Post #322068 7th Apr 2014 3:59am
munch90
can be part of spring or something in clutch plate or pressure plate has broken and is floating around and getting wedged in pressure plate causing clutch not to release fully then moves and ok then gets caught up again . this problem will feel worst on 1st or r gears and feel better has you go up the gears
does it go in gear ok when stationary and engine off if it does its not in the box , you need to try this when you having the problem not when it seems ok
not a uncommon problem on all cars
you don't normally get any strange noises
pedal will feel ok
and fault can come and go until the bit wedges in somewhere and stays there
Post #322085 7th Apr 2014 7:28am
johnr
Hey Much90,
You were spot on!! One of the springs from the clutch had somehow worked its way out and was jamming the clutch it scored the pressure plate and wreck the slave cylinder bush/bearing. So all that replaced and a new Master cylinder and slave cylinder/throw out for good measure and he's a happy beast again!!!
Cheers,
JohnR JohnR
07 Defender 110
86 M1026 HMMWV
85 Kawasaki KLR650
58 Goggomobile Dart
Post #323028 11th Apr 2014 4:59am
munch90
that's good , glad to help
Post #323097 11th Apr 2014 2:45pm
