Home > Camping, Caravanning and Holidays > Which towing mirrors do you use? |
I think it's very much personal choice. I have the flat ones, which I think are fine, but others with convex ones will tell you that they're fine too. Darren
2nd Apr 2014 8:21pm |
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 |
Thanks guys. Sorry to resurect an old topic but I'm new to Defender ownership (but loving it) and we are away with the caravan soon for the first time since getting it.
I'm going for convex. Do I need the additional extension arms? |
2nd Apr 2014 8:38pm |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 136 |
I have tried with the standard arms and have just changed to the longer arms. I found I couldn't see the sides of the caravan with standard arms.
Tony |
2nd Apr 2014 8:42pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1934 |
I find the standard arms plenty wide enough, you can move the defender arms out to give that bit extra,
2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd Apr 2014 8:47pm |
steeplejack Member Since: 27 Oct 2013 Location: Gloucestershire Posts: 53 |
If I want to see the sides properly I need to fold the nearside arm out before attaching the milenco grand aero to the top of the mirror. I can leave the offside arm in the normal position. To fit the mirrors I have removed the little pads from the thumbscrews and just trap the ball shaped end on the mirror rim.
Caravan is a Sterling Elite 2014 so 7'7"wide Still useless when it's tipping it down on the motorway |
2nd Apr 2014 8:55pm |
My Caravan is a Coachman Pastiche
3rd Apr 2014 6:49pm |
What's the Defender 2.2 like for towing the caravan? I used an X3 before and that pulled it very easily. Far better than my partners Disco 1
3rd Apr 2014 6:51pm |
I find it OK. Not going to break any speed records but nice and stable. A lot better with a BAS remap if I want to maintain 60 up the inclines, but it will use less fuel if I stick with the standard map, mainly because I then don't go so quick up the hills
Mind you I'm not one for trying to get there in a hurry. I don't believe in breaking the speed limits when towing. The caravan GVW is 1900, haven't had it weighed with all our gear on but it's probably between 1850-1900 depending on which awning we have. My last one was plated at 1900 but was surprised at the weigh bridge when it came in at 1800 exact with all our bikes and a porch awning on board. |
3rd Apr 2014 7:47pm |
Does that re-map effect the warranty? Where can I get it done?
3rd Apr 2014 8:07pm |
I don't think LR would be too keen to support warranty claims to engine and drivetrain if they know you've been running with a significant power boost.
I have my map on a spare ECU so can set it back to standard if desired. mine was done by forum sponsor Bell Auto Services (BAS) see here http://www.defender2.net/forum/topic18631.html |
4th Apr 2014 7:26pm |
Well tried the mirrors with the extended arms this morning and they were just right.
5th Apr 2014 3:22pm |
Where do you get the longer arms from.
Nice looking outfit you have there |
5th Apr 2014 3:30pm |
Your defender looks very new - what year is it?
5th Apr 2014 3:33pm |
Hi thanks for the comments.
The arms came from http://www.leisureshopdirect.com/ cost £11.42. Land Rover is over 3 years old. |
5th Apr 2014 4:16pm |
