Home > Puma (Tdci) > Low battery immobiliser and double-horn |
Hi all
I'm still trying to track down a double-horn sound ("beep beep") when I start up after the 110 has been standing unlocked for a while (doesn't happen after unlocking). I thought it was something to do with moving the OBD but today the battery was flat! I've barely been using the vehicle recently so the low battery may have been causing this problem? Any ideas - seems too much of a coincidence to me. Does anyone know if there is some kind of "horn-warning" if the alarm-system/immobiliser is getting too little juice? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Apr 2014 10:42am |
Oh crap - I hate weird
Maybe the plip has a low battery Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Apr 2014 11:14am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Low battery is shown through the alarm light
3rd Apr 2014 11:18am |
Just try something.
Put car in neutral Put a piece of tape over the Alarm sensor Put a window down. Lock the car Walk away for a minute or two Without disarming the alarm lean through the window and try to start it. It shouldn't start |
3rd Apr 2014 11:22am |
Thanks - I'll try that later - it's "Ruhezeit" - "quiet-time" here at the moment so I daren't set the alarm off
Incidentally, I've changed the plip battery and I'm charging the main battery. When you say low battery is shown through the alarm light, do you mean the main battery or the plipper - I get the solid light coming on when I switch on the ignition then the double-horn... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Apr 2014 11:46am |
Just occurred to me I need to find out why the battery ran down too Tell someone you love them today because life is short.
3rd Apr 2014 7:09pm |
Think I have the answer...
The battery was almost flat so that explains the alarm light. The Scangauge comes on shortly after the ignition comes on and the OBD then draws 70mA current (so does a BAS interface), dropping the voltage more which MAY have triggered the 10AS to have a hissy fit. Still not sure whether to do the OBD wiring again or just not use Scangauge unless to do diagnostics Thanks all Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Apr 2014 8:02pm |
