Home > Wheels & Tyres > Wobble
The Monkey
Ireland
Wobble
I fitted a set of second hand all terrains to my defender today. There only about half wore so plenty of life left in them. Only problem is they have a serious wobble at 60 mph not so much a shake but genuine wobble i had standard wheels fitted before and they drove perfect. The thing is the previous owner also experienced the same problem and that's why never fitted them. They have been balanced and are fitted to a set of disco rims ium wondering are the disco rims actually buckled.. Any tips i had a set of bfg mud terrains fitted to my last disco and it drove spot on..
Post #321109 2nd Apr 2014 7:12pm
VeeTee
Netherlands
Fitting Discovery rims on a Defender may require the use of hubcentric rings (spigot adapter rings). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #321114 2nd Apr 2014 7:27pm
Which type of Disco rims? They should be a straight swap and not require spigot rings. Darren
Post #321133 2nd Apr 2014 8:23pm
The Monkey
Ireland
Discovery stealies man nothing fancy
Post #321153 2nd Apr 2014 9:10pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
The hunk of junk jimny I am forced to drive as a daily suffers from the same. Done all sorts of things to make it better and it turns out that 2 of the tyres are not round. With them on the front it is almost impossible to drive yet on the back it is not far off right. Might be worth checking your own for being round too? Rhubarb and custard let fly with their secret weapon.
Post #321184 3rd Apr 2014 4:39am
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
I had similar issue with AT's, at about 60mph you would notice a vibration. Swapping them round improved but never got rid of the problem. The tyre fitter advised they were difficult to balance. I lived with it. I recently replaced the AT's with Yokohama's on the same rims and the vibration has gone. Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #321202 3rd Apr 2014 7:32am
Steel Disco rims are very strong and a straight fit on Defenders. It's far more likely to be the tyres as other have suggested. Darren
Post #321206 3rd Apr 2014 7:49am
munch90
there is a notice on autodata for this on the jimny
there was trouble with lower arm bushes going or just to soft
there are modified bushes to be fitted .
Post #321215 3rd Apr 2014 9:19am
The Monkey
Ireland
Got sorted today swapped the wheels around a couple of times and found a perfect combo...
Post #321281 3rd Apr 2014 2:49pm
lambert.the.farmer
Supposedly mine is new enough to have the fix from the factory allegedly. Rhubarb and custard let fly with their secret weapon.
Post #321305 3rd Apr 2014 3:47pm
