Home > Puma (Tdci) > Warranty issue - Clutch problem not covered by warranty?
Guitarplayer
Sweden 2007 Defender 110 Puma 2.4 XS CSW Java Black
Hi,
I have a -07 Defender that has been in at the dealers garage before the 3-year warranty period is ended.
They will replace, front windshield, door sealings, cd-player, windshieldwipermotor, fix the fueltank etc.
I also have a problem with the clutch, it's difficult to change gears and the clutch engage almost directly (near the floor) when you let it out. I think it maybe is the clutch bearing that is worn out but i'm not shure. However the mechanic says that it maybe not will be covered by the warranty Confused Confused Confused
So my question is do you guys have any problem to have the clutch repaired by warranty in UK (or other countries)? Any advice where to get information about documentation over clutch problem for Puma?
Best regards
Christer Land Rover Defender 110 SX Station Wagon 2007
Post #31958 11th May 2010 12:32pm
TallPaul
Think clutch is a well know problem and they changed the design?
Search the forum, lots threads on clutches... Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #31960 11th May 2010 12:35pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I live in Dubai, which is in the middle east and Land Rover Middle East clearly states they do not cover the clutch but the clutch bearing should be covered I had mine replaced because one of the springs in the bearings came loose. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #31962 11th May 2010 1:35pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
If your bearing is on its way out you can tell by pressing the clutch peddle.... when the clutch is pressed does your transfer lever stop rattling ? if so then the bearing is on its way out......and also if your under warranty and the clutch is playing up get them to replace it ...I've had 3 replaced under warranty Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #31965 11th May 2010 2:08pm
dgardel
Italy
Remember to your dealer this document LTB00166
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31967 11th May 2010 2:35pm
Eduardo
Mine has been changed by guarantee, but one of the springs of the plate fallen off.
Cheers Eduardo
Post #32019 12th May 2010 1:15am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Yes, there is indeed a known problem with the cluctch and they should replace it with the new spec clutch under warranty - they've replaced mine twice. www.ralton.co.za
Post #32020 12th May 2010 5:02am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Re: Warranty issue - Clutch problem not covered by warranty?
Guitarplayer wrote:
Hi,
Best regards
Christer
sounds exacty like mine at 17000km and also when you start it it will give a rattle from the clutch dealer changed ASAP no questions ifs or buts, and so should your dealer
Post #32040 12th May 2010 8:42am
CapeLandy
South Africa
x 2 clutches under warenty on 30K km's
Post #32047 12th May 2010 10:43am
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
...mine is being replaced under warantee next week. Clutch rattle and transmission clunks are my problem
Post #32091 12th May 2010 9:47pm
Guitarplayer
Thank you all for the information.
I took the TSB-paper to the garage and this time they said that there was a well know problem and they have changed the design on the clutch and it will be on warranty Very Happy
They will change it the first week in june when they do the rest of the warranty work. Land Rover Defender 110 SX Station Wagon 2007
Post #32354 17th May 2010 6:49am
Guitarplayer
Got my Defender back after one week at the dealer mechanics Very Happy
Yes they did replace the clutch on Warranty, they also did more Warranty work:
New heated windshield
New CD-player
New door sealings all around the vehicle
New steering ball joint and some adjustments in the steeringbox
Modified the air ventilation from the fuel tank
New sealings lower side panels
New Windshieldwiper motor and some brackets.
They have also replaced the oil pan (new oil and filter included in the warranty work)
New Brake vaccum pump
They have also replaced the injectors earlier.
My Defender is now running like a dream, when i turn the steering wheel the Defender now change direction Very Happy Very Happy and not only me but also my wife can change gears without any problem Very Happy Land Rover Defender 110 SX Station Wagon 2007
Post #33861 7th Jun 2010 9:02am
spudfan
Ireland
Indeed as it should be! Very Happy 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #33864 7th Jun 2010 10:04am
mse
New CD-player
Quick question - why did you have the wiper motor replaced, the reason i ask is mine seems more noisy that the older ones but they say its fine
Just a note on the steering box, unless the rule has changed in the last 6 months (been like it for 10 years) Your steering box shouldnt be adjusted in the warranty period by a dealer it should be exchanged
How many clutch revisions are they on now, im aware of 3 (1 = original, 2 = modified, 3rd current further modification?) Mike
Post #33867 7th Jun 2010 11:05am
Guitarplayer
mse:
I had 2 problems with the wipers, one was that the wipers didn't went back to its starting point when i turned off the switch, the other was that the wiper motor sounded like it was running very hard. Now it works perfect and the motor is quiet.
I don't know exactly what they did with the steering box but they told me that they have done some overhaul and adjustments. I think the major problem was the ball joint, because now it has a really good respons when i turn the steering wheel. Land Rover Defender 110 SX Station Wagon 2007
Post #33873 7th Jun 2010 12:05pm
