![]() | Home > Maintenance & Modifications > I'm struggling with the most basic stuff... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
I didn't want to type this in fear of looking like a completely useless muppet....
How do you take the drain plug and fill plug out the diff? I presume it's not a reverse thread? And if they're a bit stiff any warnings on damaging anything (other than myself) ? |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Just a normal thread. Be sure to do the filler first then you can get fluid back in. Rhubarb and custard let fly with their secret weapon.
Thanks mate.....
Ruddy eyes almost popped out. Flamin king Kong must dun them up! I need to go and sit down...... Strange undid the fill first and loads of oil came out....and no I wasn't standing on my head ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
its usually about having the right tools! in your case a decent breaker bar!. i remeber a few year ago trying to undo some radius arm bolts. had a 2ft breaker bar tried everything!! couldnt shift them. my mate then showed up with a 3 ft bar and they came off easy!!! My 109 thread
my youtube channel |
W
![]() A breaker bar........ ![]() I thought you were having a laugh. Job done thanks.......will be trying transfer box soon ![]() |
Be really careful not to overfill - check the manual
It's because they're used for breaking sockets ![]() |
Bpman.....
As you can see the diff was overfilled.... ![]() Click image to enlarge What issues are limited to arise? I've just refilled to fill point which I believe is circa 1.8ish ltrs and therefore more than the 1.6 Ltr mentioned in handbook... should I be worried? |
I feel I may have to put my hand up to being a complete imberseal.
Have moaned and moaned about my engine i've now done a few hundred miles since new turbo And the Knocking / clatter noise is almost certainly the transmission.....hence I'm on the case of changing the fluids as a starting point but I worry it the clutch or gearbox extension AGAIN ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Have you changed front diff oil yet?
Andy |
so your saying that the garages you took it to many times could not tell you it was gearbox issue and not engine , maybe time to look for a proper garage and not fitters
Yep. Done tonight
![]() Ignoring the poor performance in my biceps it was an easy job |
Munch90....hadnt thought of it like that
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3653 ![]() ![]() ![]() |
Has Lorryman had a chance to look at it yet? DEFENDER 90 TDCI XS,
