Home > Maintenance & Modifications > I'm struggling with the most basic stuff... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
I didn't want to type this in fear of looking like a completely useless muppet....
How do you take the drain plug and fill plug out the diff? I presume it's not a reverse thread? And if they're a bit stiff any warnings on damaging anything (other than myself) ? |
25th Mar 2014 4:40pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Just a normal thread. Be sure to do the filler first then you can get fluid back in. Rhubarb and custard let fly with their secret weapon.
25th Mar 2014 4:46pm |
Thanks mate.....
Ruddy eyes almost popped out. Flamin king Kong must dun them up! I need to go and sit down...... Strange undid the fill first and loads of oil came out....and no I wasn't standing on my head |
25th Mar 2014 5:05pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
its usually about having the right tools! in your case a decent breaker bar!. i remeber a few year ago trying to undo some radius arm bolts. had a 2ft breaker bar tried everything!! couldnt shift them. my mate then showed up with a 3 ft bar and they came off easy!!! My 109 thread
my youtube channel |
25th Mar 2014 5:31pm |
W
A breaker bar........ I thought you were having a laugh. Job done thanks.......will be trying transfer box soon |
25th Mar 2014 6:01pm |
Be really careful not to overfill - check the manual
25th Mar 2014 6:30pm |
It's because they're used for breaking sockets |
25th Mar 2014 8:06pm |
Bpman.....
As you can see the diff was overfilled.... Click image to enlarge What issues are limited to arise? I've just refilled to fill point which I believe is circa 1.8ish ltrs and therefore more than the 1.6 Ltr mentioned in handbook... should I be worried? |
25th Mar 2014 8:08pm |
I feel I may have to put my hand up to being a complete imberseal.
Have moaned and moaned about my engine i've now done a few hundred miles since new turbo And the Knocking / clatter noise is almost certainly the transmission.....hence I'm on the case of changing the fluids as a starting point but I worry it the clutch or gearbox extension AGAIN |
25th Mar 2014 9:01pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Have you changed front diff oil yet?
Andy |
25th Mar 2014 9:05pm |
so your saying that the garages you took it to many times could not tell you it was gearbox issue and not engine , maybe time to look for a proper garage and not fitters
25th Mar 2014 9:08pm |
Yep. Done tonight
Ignoring the poor performance in my biceps it was an easy job |
Munch90....hadnt thought of it like that
25th Mar 2014 9:14pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
Has Lorryman had a chance to look at it yet? DEFENDER 90 TDCI XS,
26th Mar 2014 6:40am |
