Home > Puma (Tdci) > Air Con
mse
Air Con
Air Con recharging...is this a warranty item? Mike
Post #31885 10th May 2010 4:37pm
I bet is isn't Shocked
Post #31888 10th May 2010 4:45pm
mse
Well it doesnt say in the book it is! Mike
Post #31889 10th May 2010 4:49pm
where does the gas go ?
If there is no leak it would still be there, but because its a gas, they will charge for it..
Post #31891 10th May 2010 4:55pm
mse
It works its just not efficient.
On any warranty task - any fluid removed is replaced new for free (hence my sump oil cost was dicounted off the service price) Mike
Post #31894 10th May 2010 5:15pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
mine was re charged under warranty
Post #31897 10th May 2010 5:33pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Mine was recharged also but they were explicit that it isn't a warranty item. I think they felt bad that they'd not been able to sort out the other items I'd flagged (and had caught them on the hop for not doing their job properly last time). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #31902 10th May 2010 5:59pm
MK
Dont think so, but any leak should be fixed under wty Puma 110" SW
Post #31906 10th May 2010 7:36pm
mse
Ill see what they say - its not as efficient as 2yrs ago Mike
Post #31921 10th May 2010 10:44pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Because it's a gas, it will leak over time - like air in tyres...
As I understand it most rubber etc. is very slightly porous to air molecules.
Either way, I think it's a normal service item, every 3 years or so it should be topped up.
Post #31964 11th May 2010 1:48pm
TJ101
Yep, will be classed as a service item,
Will give mine a snort of gas, before a wee little trip south next week Thumbs Up
R134 does seam to "disappear" not like the good old R12 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #32017 11th May 2010 10:56pm
Its nothing to do with Gas its something in the gas that lubricates the seals when the AC is on if you dont turn it on the seals dry and the gas escapes
I know this as I preech it every summer to our peeps who say their air con dont work first question I ask is do you turn the AC off
Oh once the seals dry out they are never the same Me I never turn the AC off at all when in the car Summer / Winter AC has its merits
Cars with Climate control suffer way less from this issue and I generally get the regass FoC on a CC vehicle but AC ones are a battle
Post #32026 12th May 2010 6:44am
CFB
If they want to charge you for it check the price first as Kwik Fit were doing a deal to re-charge air-con for £25 recently, had the wifes Zafira done and it was spot on afterwards! Andy
Post #32027 12th May 2010 6:49am
mse
Weirdly it seems to work better when you start it from stationary (eg cools colder) than when your driving along Mike
Post #32060 12th May 2010 3:27pm
roel
That's normal for a defender. When you drive more outside air flows in through the gaps. Roel
2003 90 Td5 (2009-now)
Post #32063 12th May 2010 4:23pm
