Home > Puma (Tdci) > Air Con
Page 2 of 2 <12
mse
roel wrote:
That's normal for a defender. When you drive more outside air flows in through the gaps.
No this isnt normal at all - i might not be explaining it. Mike
Post #32071 12th May 2010 6:18pm
T1G UP
you can buy the recharge canisters from halfords etc, just done the wifes car. theres enought to another couple of goes too.
our local halfords was selling this @ £24.99 with the matrix cleaning bomb!
Post #32073 12th May 2010 6:57pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
mse wrote:
Weirdly it seems to work better when you start it from stationary (eg cools colder) than when your driving along
Think I know what you mean Mike - I had noticed this to some extent - I figured it's either the normal heater matrix heating up (and leaking heat into the system somewhere) or maybe a thermostat on the a/c unit itself, cycling the pump on & off once it's reached it's normal operating temp..?
Post #32106 13th May 2010 9:35am
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
This is a bit of a gamble, as you have no idea how much charge is left in the system. Too much gas can be just as bad as not enough. The system will have been designed and tested (hopefully!) using a "charge determination test" to ensure the correct charge for the right degree of sub-cooling. Sub-cooling makes sure that all of the gas from the compressor is condensed into a liquid before returning to the expansion valve and evaporator. I hope that's not too technical.
Best bet, in my opinion, is to get a re-gas done professionaly. De-gas and re-cycle, new receiver/drier, vac-down and re-charge.
Hope this helps.
In a previous post from Ken he mentions the lubricant. This is in the compressor to start with, and a percentage gets mixed with the refrigerant as the system cycles.
Post #32769 22nd May 2010 3:23pm
T1G UP
the canister i used had a guage fitted. we'll be buying an aircon recharging machine next year so it won't be a problem.
Post #32886 24th May 2010 9:16pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I actually think the same as my car is always in the shade from the scorching sun here in dubai, as temperatures reach up to 50 degrees, my a/c does put alot of stress on the engine especially in traffic. When back on the motorways my a/c does start cooling again. Wish the defender had cooling seats Mr. Green '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #32949 25th May 2010 8:21pm
Page 2 of 2 <12
