Home > Technical > Nas step and trailer electrics |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Yep thats right, I bought a cheapo bracket that fits behind the tow bar on standard cars and modified it to fit repainted waxoyled and it's pretty neat, there is probably a better/proper fit but i couldn't be arsed to find it/pay for it/invent it......delete as necessary. I'll take a picture tomorrow Original Member Pie n Pea Club.
110 HCPU Tipper |
26th Apr 2010 9:56pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
With the NAS step doesnt the socket go in the hole in the cross member??
26th Apr 2010 11:03pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
Thats almost wha i did - the paint bit. At least thats how it should be which is what i wanted to check
If that were true the problem is the loom doesnt fit through and you would have to drill the mounting holes Mike |
26th Apr 2010 11:09pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Loom does fit
27th Apr 2010 5:56am |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 |
This thread needs pictures Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?) |
27th Apr 2010 7:53am |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
What ken said...ive just pulled mine through taught at the moment before how i work out how to mount securely You cannot teach stupid people to do clever things
27th Apr 2010 9:57am |
The plug on mine definately didnt fit - it went through the square hole but not the round one at the back - no way the plastic lugs either side both prevented it Mike
27th Apr 2010 5:04pm |
Take the round plug apart
27th Apr 2010 7:31pm |
It was too well sealed to ruin it by doing that...and then drill the cross member to put the bolts through and introduce corrosion?! Mike |
27th Apr 2010 7:58pm |
The round socket tis easy self tappers and sealant will be fine
27th Apr 2010 8:31pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I don't have a NAS bumper but the loom should easily fit through the hole in the crossmember.
Click image to enlarge One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
27th Apr 2010 8:48pm |
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 |
nas step and tow plug in cross member, no problem
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
10th May 2010 10:36am |
So you all dismantled the socket end and fed the wires in?
Dont get me wrong i like it in there but didnt want to dismantle it and introduce corrosion in the crossmember by drilling it and ingress into the connection! Mike |
10th May 2010 4:42pm |
The bumper surely doesn't change things
If it still leaves the standard hole then you should be able to feed the socket through (takes a bit of a wiggle to work out the right angle ). I drilled the cross member and used rivnuts to secure the socket. You don't have a lot of room so make sure you get it right the first time. I didn't paint the exposed metal in the cut and I used aluminium rivnuts in the steel cross member . Never mind, I'll need a new one some day anyway One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
10th May 2010 5:53pm |
