Home > Technical > Nas step and trailer electrics
mse
Has anyone fitted the genuine trailer electrics to their NAS bumper.
I was expecting a direct fit - instead i had to make a bracket is that right? Mike
Post #30757 26th Apr 2010 8:00pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yep thats right, I bought a cheapo bracket that fits behind the tow bar on standard cars and modified it to fit repainted waxoyled and it's pretty neat, there is probably a better/proper fit but i couldn't be arsed to find it/pay for it/invent it......delete as necessary. I'll take a picture tomorrow Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #30763 26th Apr 2010 9:56pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
With the NAS step doesnt the socket go in the hole in the cross member??
Post #30770 26th Apr 2010 11:03pm
mse
Thats almost wha i did - the paint bit.
At least thats how it should be which is what i wanted to check
If that were true the problem is the loom doesnt fit through and you would have to drill the mounting holes Mike
Post #30771 26th Apr 2010 11:09pm
Loom does fit Thumbs Up
Post #30777 27th Apr 2010 5:56am
TallPaul
This thread needs pictures Cool Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #30784 27th Apr 2010 7:53am
discocuzzy
What ken said...ive just pulled mine through taught at the moment before how i work out how to mount securely You cannot teach stupid people to do clever things
Post #30797 27th Apr 2010 9:57am
mse
The plug on mine definately didnt fit - it went through the square hole but not the round one at the back - no way the plastic lugs either side both prevented it Mike
Post #30866 27th Apr 2010 5:04pm
Take the round plug apart
Post #30891 27th Apr 2010 7:31pm
mse
It was too well sealed to ruin it by doing that...and then drill the cross member to put the bolts through and introduce corrosion?! Mike
Post #30895 27th Apr 2010 7:58pm
The round socket tis easy self tappers and sealant will be fine
Post #30905 27th Apr 2010 8:31pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I don't have a NAS bumper but the loom should easily fit through the hole in the crossmember. Thumbs Up
 One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #30910 27th Apr 2010 8:48pm
beetroot
nas step and tow plug in cross member, no problem
Post #31853 10th May 2010 10:36am
mse
So you all dismantled the socket end and fed the wires in?
Dont get me wrong i like it in there but didnt want to dismantle it and introduce corrosion in the crossmember by drilling it and ingress into the connection! Mike
Post #31887 10th May 2010 4:42pm
alantd
The bumper surely doesn't change things Question
If it still leaves the standard hole then you should be able to feed the socket through (takes a bit of a wiggle to work out the right angle Whistle ).
I drilled the cross member and used rivnuts to secure the socket. You don't have a lot of room so make sure you get it right the first time.
I didn't paint the exposed metal in the cut Embarassed and I used aluminium rivnuts in the steel cross member Embarassed . Never mind, I'll need a new one some day anyway Very Happy One that started out as a 2.4 TDCi 110 XS
Post #31901 10th May 2010 5:53pm
